Major misfire on startup
b-mack
California
I’m hoping someone has an idea for this one: My 2020 has a little over 20k and has never had a single issue with the engine. Today, after the truck was pretty warm but not driven in the last hour, I went to start it up and it was like I had a dead cylinder. Barely running, shaking all over, surging, trying to die….just like if I pulled a plug wire or two. I shut it down, waited about 5 seconds and restarted and all was fine again. No check engine light and it didn’t throw a code. I drove it the rest of the day and nothing else has happened but that would be a stranding level event if it didn’t go away. Any ideas? Can the computer just glitch like that?
CoronaRaptor
CANADA
Welcome to the place, congrats on your raptor. There may be a code stored, but you will need to download Forscan to check. You will also need an adaptor to connect from your laptop to your truck. In the meantime I would check your intake for loose hoses, etc. Is it stock?
b-mack
b-mack
California
Yup, totally stock. I didn’t have time to do an under hood check but I will tomorrow…just seems odd it would spec correct like that and give no other occurrences.
b-mack
b-mack
California
Thanks, will do. I’ll give it a full look over tomorrow. I would have thought a code would pop up but none were found when I had the local parts store run a scan.
GCATX
King Dingaling
Central Texas
Are you running a Pedal Commander? It gave me some issues. Beyond that, there may just be a ghost in the machine. Mine has done few random things that were fixed by a restart, never to be repeated. I have 86k miles now. One time the oil pressure light came on with lots of beeps from the dash. No idea why, that was about 40k miles ago. Something just glitched or didn't boot up right. Dunno.
CoronaRaptor
CANADA
Sometimes I think our cell phones cause issues
b-mack
b-mack
California
No, no mods or extras whatsoever. It’s good (I think??) To hear it could have just been a random one time event. That’s kinda what it seemed like since it was simply gone with a restart.
EastEndAngler
Long Island, NY
@b-mack - same M/Y and milage (just crossed 20k on the odometer) - I haven't experience symptoms as drastic as what you describe but as of recent I do feel like the truck is idling a bit rougher upon first start. It's noticeable enough to me that I was researching spark plug yesterday....
Macdaddy
Twin Cities, Minnesota
I’m same truck 2020 802a 21k miles. At about 17k miles mine did shimmy shake almost like urs sounds like. But shut off. Started again and has run perfect ever since. When I had it in for oil change had them check for codes and none! Just a glitch in the matrix.
