LVJ hi-beam relay and GJ 3rd brake light installed
4wheelinAZ
AZ
That LVJ relay looks like a great option for amp hungry lights. When installing do you still keep the upfitter wires going through the factory fuse block as well?
FmaxTurboSi
FmaxTurboSi
So Cal
Yes still goes through the factory fuse block. The oem upfitter now act as an on/off switch for the hi-beam relay.
The LVJ unit is solid.
MrBuddha
NorCal
I can vouch for LVJ relay panel as well...the unit is well built with a thoughtful choice of sleeves, stout wiring, and cable labels to make installation straightforward. The included instructions are for the Gen 2, but it's fairly easy to map the wiring to the Gen 3 aux wires.
Also, the metal bracket fits the battery tray mount points on the Gen 3 with no problems as well.
catinthehat85
Socal
Curius does this work? I think I read in another post somewhere the relay is actually triggered by the fogs? I would have to have my fogs on all the time for this setup to work properly?
FmaxTurboSi
FmaxTurboSi
So Cal
It’s connected to the fogs yes, but it works the opposite. When hi beams are on, theoretically the fogs turn off.
So when the fogs are off, it turns the LVJ relay on. If that makes sense.
