Lucas fuel treatment anyone
GatorBait
Bradenton, FL
Anyone ever try this Lucas fuel treatment? Says you can use instead of paying for premium fuel. Just used for first time along with premium fuel. Will see if it makes any difference with fuel consumption.
FordTechOne
Detroit
I’m not aware of any data showing how effective the Lucas fuel conditioner is, but it does not increase octane, so if you use anything less than 93 you will see a decrease in performance and fuel efficiency.
Any reference to fuel octane would be in the context of carbon buildup causing knock, resulting in the need to use higher octane. Modern engines run much cleaner and the PCM controls timing to eliminate that scenario, so that is an outdated claimed benefit.
If you run top tier fuel there should be no need to run additives such as this.
Azrael
Home of football
They make a great product for diesel engines that cleans/lubes injectors, AND also cleans the DPF. However, on a gas engine, I think that Chevron makes the best for cleaning/lubing the injectors. It has Tecron in it that really seems to be the market favorite. With the standards of gasoline delivery and tank status at the stations, this Chevron stuff is cheap insurance to protect your injectors.
Donovan
DC
Why are there certain tunes that are called "91 octane?" Am I to believe that said tunes allow the Raptor to run on 91 octane?
Azrael
Home of football
For reference, Ford tuning will allow you to run on 87 octane without hurting the engine. Their tuning is adaptive to octane as most manufacturers are these days.
Donovan
DC
Very interesting.
Now, if they "retune" it to run 87, will that gas mileage reflect as worse or equal to stock gas mileage?
87 gas mileage with tune and without the tune?
DFS
Mars
Very interesting.
Is 87 octane fuel as energy dense as 93? No, so fuel mileage would decrease.
FordTechOne
Detroit
Very interesting.
You’d still be limited by octane regardless of tuning. The engine is designed for 93 octane, which is what the power output figures are based on.
Mister Pinky
OH
Chevron Techron is the only additive I’ve seen referenced and approved by factory service information.
Herk91
Kansas City
In my owners manual, Ford says that 87 octane is fine....power output is 401...6.2L. 91 octane or above power output is 411...6.2L motor.
tgrayson
Fairway Row Ln, Charlotte, NC
I have used the Lucas fuel conditioner in my 2014 6.2 engine for over 4 years and it works great. I don’t believe it claims to increase octane in fuel but to allow lower octane use? Anyway, I use it for the injector and valve cleaning properties and upper cylinder lubrication. It works very well with the oil/air separator to keep the intake air clean. It also gives better fuel economy on trips. You can buy it in gallon size to make it economical to use.
KOBRA2848
I haven’t used this in my Raptor since it’s a pain to add anything to the tank with the cap less fueling. I have used it in the wife’s Shelby and her Cobra before and did see an improvement in fuel mileage after running it. I do think running anything less than premium in any Raptor is foolish because you loose some of the fun factor.
Mark
K223
Florida
Under boost its a whole different ball game vs a N/A engine, unless maybe it’s a very high CR motor. 87-93 under the stock tune your talking about a 50HP power difference. Besides many company’s don’t even add any cleaners to the 87 octane fuel.
Donovan
DC
Which one?
https://www.amazon.com/dp/B000FW7V50/?tag=fordraptorforum-20
https://www.amazon.com/dp/B000ARPVOI/?tag=fordraptorforum-20
https://www.amazon.com/dp/B0006305RY/?tag=fordraptorforum-20
https://www.amazon.com/dp/B003JTYGPO/?tag=fordraptorforum-20
https://www.amazon.com/dp/B00574RXEU/?tag=fordraptorforum-20
101,284
60,415
Gerth
