Lower Control Arm Bracing Kit
khcdave
South Brunswick NJ
Kit is ready for sale. It will include front u shaped weld in bracket that gets welding in after trimming the pocket, 2 bracing plates for rear pocket that get welded into place and the main support brace which is the last peice that gets welded in. The parts are made from 3/16 and 1/4 steel. Shown in the pics is our truck that doesnt run a swaybar. The brackets can either be trimmed short of the sway bar or notched around the bar.
A few notes:
1) longer rear bolts are required
2) You can slot the holes if you want to allow for alignment adjustment but cams will so longer work
3) Idealy this kit is used to lock the lowers in place and use adjustable ucas to align and adjust. I lock them all the way to the outside for slightly more track width.
4) some modification and grinding will be required since all trucks are different
Price for kit is $199. Pm me or call the shop to order. Thanks
khcdave
khcdave
South Brunswick NJ
Hey Joe. The holes can be slotted just like the factory ones and the pin hole drilled to except the cam plates. If you want ship them to me and I will get them all ready for you no cost. Ship them flat rate usps
LONGISLANDRAPTOR
Long Island, NY
I want a set of these bad! After HAVOC I noticed my passenger front mount is smashed.
these can be slotted and pinned to use alignment cams?
I will be running RPG Upper arms eventually and they are non adjustable so having factory lower arm adjustment is needed.
Labraptor
Illinois
Good idea, have smashed mine quite a few times. Last year at Havoc got them pretty good.
