Just recently purchased my 2020 agate black raptor and have been looking at SO many different fog light kits .
I really want to know which are the best to choose from...
The price obviously vary quite a bit but I see the going price tends to be around $800 and I don't want to drop the doe on one that isn't worth it.
Id be interested in seeing or hearing about any other added on or modified lights too.. im looking to eventually get more then just the fog lights.
Pics would be awesome too
Before answering this question, it would help to know what your use case is, and how you will use the lights - and truck.
Secret prius owner trolling us?
mall crawling poseur?
keeping up with the Jones’s?
Street only / 26’s with negative offset?
You dabble?
off road for hunting, fishing, or to get to a remote cabin?
Overlander?
Some recreational off roading?
Some pretty serious off roading?
Magazines write stories of your off road exploits?
You own the magazines, and this is one of several off road vehicles you also own?
If you’re honestly in the last 4 categories, seriously consider holding off on the pocket light kits and get a decent grille light or some XL80 pillar mount lights instead. Low mount lights are more easily obstructed by terrain.
If you’re under those last 4, pick a brand / pair of lights + a mount and don’t opt for an entire kit. Instead, wait for the Black Friday vendor sales and save some $$$.
Next question is whether or not to use up a slot for SAE lights. If you need an SAE light, and they do help, then it’s probably best to pick them up first.
If you do go with an SAE pod, I’d put a pair of driving combos on each side. I have spots and driving combos now and need to swap out the spot lenses. For the distance I get with the combos, I like the extra spread of the combo lights better in the low mount position.
if you don’t need the SAE light, I’d go wide corner and 2x driving combos per side. The wide corner is great for lighting up the area the close to the truck and everywhere around it. It will be practically impossible to be surprised by a roadside forest rat attack.
The S8 behind the grille is a great option too. It’s bright as ****. You will not be disappointed.
Black Friday isn’t far off and will save lots from our supporting vendors. They’ll steer you correctly quality wise.
