LOADING TUNE PROBLEM...?!
Discussion in 'Ford Raptor Engine Discussion and Performance Mods' started by BarryG, Jan 17, 2020.
  1. BarryG
    BarryG Full Access Member
    62
    12
    Sep 1, 2019
    Park City, UT
    Help. I’ve started getting all kids of malfunction warnings, etc...!! I was loading a tune through my NGauge, forgot I was doing it, got it and hit the start button at about 80% or more of the tune loaded. Sad “tune loaded successfully” but then I started getting all the alerts. Loaded another tune - same thing. ALL KINDS of malfunctions/Alerts/cautions! Power steering went out too!
  2. Johnkn
    Johnkn Full Access Member
    751
    434
    Nov 29, 2018
    LaPlata, MD
    You were loading a tune on the truck and then forgot you were loading a tune on your truck?
    Sunchild714 likes this.
  3. BarryG
    62
    12
    Sep 1, 2019
    Park City, UT
    Yep. Spaced it. Totally forgot I was loading a tune... got in hit start. All kinds of shit going haywire now. It runs fine - just malfunction alerts, and no power steering.
  4. TwizzleStix
    TwizzleStix FRF Supporting Member Supporting Member
    120
    119
    Mar 4, 2019
    Commifornia
    Remove tune and then reload correctly.
  5. Sunchild714
    Sunchild714 Member
    41
    25
    Apr 14, 2019
    Las Vegas
    Did said tune take a back-up of the original config prior to loading? You can restore then start all over.
  6. Blown00gt
    Blown00gt Full Access Member
    192
    144
    Nov 12, 2018
    Arkansas
    Agreed. I would try and load your stock tune back drive it then reload MPT tune.
  7. MTF
    MTF FRF Addict
    4,213
    1,194
    Nov 27, 2010
    NYC
    A little tip when loading a Tune.
    You should not be doing anything else like,
    opening doors, rolling the windows up or down or anything that would trigger a current change.
    You should have all electronics turned off like,
    auto lights, climate controls, radio and make sure alarm won't set during the tuning process.
    As others have said return back to stock and if successful, do a battery disconnect for 10 to 15 minutes.
    Then try to reload your Tune.
    1BAD454SSv2 likes this.
  8. BarryG
    62
    12
    Sep 1, 2019
    Park City, UT
    @MTF - I’m Gonna try and reload, then KAM reset. I flashed it back to stock, didn’t KAM reset, and same problem. I’d reflashed Stock, drove it, then did KAM. I’ll try again in your order.
    MTF likes this.
  9. Oldfart
    Oldfart Full Access Member
    383
    432
    Oct 21, 2017
    United States of Trump
    At least tell us you just got done with a big fatty! :pimp:
    BarryG likes this.
  10. BarryG
    62
    12
    Sep 1, 2019
    Park City, UT
    @Oldfart - I mean.... I WAS DEFINITELY visiting Colorado for a sled trip.
    Oldfart likes this.
Share This Page
