Help SupportFord Raptor Forum by donating:
Help support Ford Raptor Forum :
lighting question for Rigid D lights
Discussion in 'Rigid Industries LED Lighting' started by mudblood, Mar 11, 2014.
  1. mudblood
    mudblood FRF Addict
    71
    1,429
    609
    Nov 11, 2013
    Atlanta
    Now I am being told Rigid changed the wiring harness and these lights may or may not work with present harness. May have to rewire everything. Duoooo!
  2. justvettn
    justvettn FRF Addict
    4,359
    916
    Feb 9, 2012
    GTA
    Thats right I would probably swap your 30Amp fuse for a 15 you can get at most autoparts stores. Don't pull your 15 and 30 and switch those back and forth because you have lighter gauge wires for switch 3 and 4.
    When I had Rigid on the phone, I asked them about swapping fuses for lower recommended amp ones. They said it was a good idea but that the lights were internally protected as well.
    ---------- Post added at 03:40 PM ---------- Previous post was at 03:36 PM ----------
    Rigid changed plugs a while back and I have pictures on the forum of the two different styles.
    They will also send you an adaptor plug free of charge if you have the old style plug, if you want to do it that way.
    Found the picture.
    [​IMG]
  3. mudblood
    mudblood FRF Addict
    71
    1,429
    609
    Nov 11, 2013
    Atlanta
    Thanks for the information. My plugs are gray on the outside but They are more square and less rounded. I assume that is the newer harness you are showing. The one closest to your palm or the inside of your hand. I want to thank you for all your great information. Folks like you really help us dummies. Gonna gone Rigid a call now that I know I am good to go.
  4. justvettn
    4,359
    916
    Feb 9, 2012
    GTA
    Yes the new style is the grey square one, so you should be fine.
  5. mudblood
    mudblood FRF Addict
    71
    1,429
    609
    Nov 11, 2013
    Atlanta
    Again thanks so much for your information. This is the main reason I enjoy using this forum.:mwah1:
Share This Page
