Light Up the Trail — Bronco Raptor Ditch Light Upgrade by M&R Automotive
MandR Automotive
Forum Members Receive a 10% DISCOUNT!!! Use Coupon Code FORDRAPTORFORUM
If you’re running a 2022+ Ford Bronco Raptor, this ditch light setup from M&R Automotive is one of those upgrades that just makes sense.
Designed for serious visibility without the clutter, the Ditch Lights PRO kit gives you a clean, factory-style mounting solution that puts light exactly where you need it when you're off-road or driving in low-visibility conditions.
What stands out:
  • Purpose-built for the Bronco Raptor platform
  • Clean A-pillar / ditch mounting for maximum forward spread
  • Rugged off-road performance with a factory-style fit
  • No guesswork install — designed for a straightforward bolt-on setup
  • Built for trail runs, night driving, and backcountry adventures
This is one of those mods you don’t fully appreciate until you’re out in the dark and can actually see everythingin front of you.
Check it out here
Anyone here running ditch lights on their Bronco yet? Curious how others are setting theirs up.
MandR Automotive
MandR Automotive
Bronco Raptor Ditch Light Upgrade​
Throwing it back to this quick install tutorial from Mike at M&R Automotive. These dual-function ditch lights feature a bright white main beam and an amber backlight that perfectly matches the Bronco Raptor's factory accent lighting.
A simple upgrade that adds both style and functionality.
101,310
60,412
hugecrankfonz
