LeePowerSteering
- Joined
- Aug 23, 2018
- Posts
- 2
- Reaction score
- 10
Hello Raptor Forum!
We are proud to introduce our Power Steering Kit for the gen 1 6.2 Liter Raptor
The Lee replacement system starts with our 8-inch finned reservoir securely mounted in front of the core support for oil storage and better cooling all in one.
We couple that with our tried and true Lee cast iron TC pump with custom flow control outlet, high flow inlet, billet aluminum pulley and billet aluminum adapter bracket. Also, part of the system is a Lee inline 6 GPM oil filter with replaceable element to ensure no unwanted particles are ever in the system.
The kit comes complete with the pressure hose, return hose, -12 oil inlet line and all mounting hardware.
The system is also designed to eliminate the annoying hydraulic vibration that occurs when replacing the stock lines. This is done with a custom resonance deleting -6 high pressure line.
We are currently working on a reservoir set up that will work with behind the grill light bars as well!
The kit can be found here: https://leepowersteering.com/collections/all-products/products/stg-pump-kit-ford-raptor
I will be on here to answer any questions you may have
Send It!
-Ryan
Send It!
-Ryan
