Led halo
Discussion in 'Raptor Retrofit' started by may28th, Apr 8, 2014.
  1. may28th
    may28th Full Access Member
    71
    Aug 8, 2011
    va
    Hey guys let me first start off by sayin I love my retro fits. I have had them for about 2 years, well I noticed today the both halo rings are starting to go bad I think, the passenger side is missing a few lights and the driver side is
    Missing several and is flickering a lot and no where near as bright as the passenger. Could this be something other then the led rings them selfs or am I going to need to replace them. If replacement is necessary can I send the lights to you Dawson and have them replaced.
  2. NickPic83
    NickPic83 FRF Addict
    36
    9,641
    2,434
    Jan 31, 2012
    Rockland County NY
    If individual leds are out then its probably the rings and that is not good at all. They may have to be replaced and depending how its attached it could destroy the shroud in the process. I would contact Dawson directly and see what he says
  3. may28th
    71
    Aug 8, 2011
    va
    Does anyone have a contact number, I just hard wired them directly to 12v and no change
  4. NickPic83
    36
    9,641
    2,434
    Jan 31, 2012
    Rockland County NY
    Dont have it maybe try a PM or contact him thru his site
  5. treatcg
    treatcg Full Access Member
    299
    108
    Oct 10, 2013
    Oklahoma
    Dawson Sears
    518.302.6008
  6. Raptor Retrofit
    Raptor Retrofit HID Specialist Supporting Vendor Supporting Member
    44
    1,970
    1,173
    Jul 22, 2010
    NY
    Took care of it a while ago, thanks though guys!
  7. svt87
    svt87 Member
    40
    Jan 30, 2012
    Toronto, Ontario, Canada
    Did you just end up replacing them? Because I'm getting the same problem.
    Sent from my Nexus 7 using Tapatalk
  8. treatcg
    299
    108
    Oct 10, 2013
    Oklahoma
    I would like to know how you replace these since they are glued in and the light assemblies have to come apart again. Isn't baking them apart a difficult task?
Share This Page
