Is there a way to leave the engine running and lock the doors? For example, I drive less than a mile to stop for a cup of coffee and engine is not up to temp. I would like to leave it running and lock the doors when I grab a cup.
I've tried to lock it with the button on the door but it will not allow it to lock with key in ignition.
Thanks
The button trick will not work.
The only way I have found to lock the doors while the key is in the ignition I'd to do the following.
1) start the truck with key in the ignition
2) put down your drivers side window
3) exit the truck and close the door
4) reach inside the truck through the open window and lock the truck
5) hit the auto window up on the driver side and remove hand quickly without hitting the window add it moves upward
6) your truck is now running with Windows up and locked.
7) to unlock you need the other key OR use the number code to unlock the truck
Thank You for your donations to Avery. We hit our goal!
Yukon Joe
Snoball 3
Delta Lead
www.runraptorrun.com
