Leaking Valve Cover source of my misfires?
Quiker
Austin, TX
I’ve been chasing misfires for a while - 304,305,306 - all one the one side - and P2282 - Air Leak Between Throttle Body and Intake
I pulled the intake off today - to find oil seeping out of the value cover bolt near cylinder #4 intake port.
I don’t mind a small oil leak - but I will go through the pain to pull and reset that valve cover if it’s likely the cause of my issue
Raptor Valve Cover Leak.jpg Do you think a leak in the valve cover end up causing a my troubles?
Granelli
Nevada
Any update on this? Noticed a leak on my driver side valve cover at the very back. Drips down near the turbo.
Quiker
Quiker
Austin, TX
Turned out to be a ECU tuning solution- my BBK throttle body is too much of the ecu to self adjust - added that to the tuning
