Nice find. I called local dealer and he said he didn’t have a part number for any o-ring, gasket, etc.
I am thinking of cleaning the area with brake cleaner, swapping fluid, and adding new cover with lube locker gasket to see if the leak persists.
Do you know if I can remove the plug attached to the housing without causing any issues to the inner workings of the locker? I assume that the wires inside the housing simply unplug from the connector once the bolt is removed and then you can slide the new o ring on.
Thoughts?
Thoughts?
