GEN 2 Knock sensor code p0325
Punta Gorda fl
Knock sensor code p0325. Truck hasnt been feeling strong lately and this code just popped up, doesn't run rough and don't here any new noises I'm hoping for just a bad sensor but does anyone know if this will engage a limp mode causing the feeling of lack of power?
FordTechOne
Detroit
Thanks for the reply! Sensors look cheap online any knowledge how extensive the job is to do? It's a 2017
You’ll want to check the wiring first to make sure there’s no rodent damage, chaffing, etc. The sensors are located in the valley of the engine; to access them the intake manifold, port injector rail, and direct injector rail all need to be removed. Removal of the DI rail requires replacement of the pump to fuel rail tube, as it’s one time use. That also requires a line wrench torque wrench, a special tool to clean the injector bores before reinstallation, a special tool to replace the injector seals, and a special tool to size the seals. Unless you can get access to all of those things, it’s probably best left to a dealer/shop.
