KMC Enduro Beadlock Bolts
Discussion in 'Ford Raptor Wheels & Tires Forum [GEN 1]' started by tnsbruce, Jun 5, 2012.
Sponsored By: Texas Motorworx
  1. tnsbruce
    tnsbruce Full Access Member
    55
    Feb 6, 2011
    Howdy -
    I have the KMC Enduro wheels on my Raptor. The wheels came with Grade 8 bolts to attach the beadlock to the wheel. Can I replace the the Grade 8 bolts with stainless bolts? Stainless bolts are not as strong as Grade 8, but I am thinking the threads in the aluminum wheel are the weak link.
    Thanks
  2. AngryBird
    AngryBird FRF Addict
    1,353
    282
    Jan 31, 2012
    Near Santa Fe, NM
    No! Hell No! The threads are not the weak link or they wouldn't spec Grade 8 Bolts. You can do the thread failure calcs if you want to prove this to yourself. You will not be able to achieve the necessary pre-load on the bolts to hold the lock ring on under pressure. This could lead to failure under pressure and consequently severe injury and/or death.
  3. vanilla_gorilla
    vanilla_gorilla FRF Addict
    2,520
    1,000
    May 25, 2011
    NorCal (Sacramento)
    Can I ask why you want to swap put the provided bolts?
  4. tnsbruce
    55
    Feb 6, 2011
    Glad I asked! Grade 8 will stay. I was getting some corrosion on the bolt heads. I will clean off and stick with the Grade 8 bolts.
    I will do some research on the thread failure calculations - it will be an interesting exercise.
    Thanks!
  5. vanilla_gorilla
    2,520
    1,000
    May 25, 2011
    NorCal (Sacramento)
    And if you are getting corrosion, i would suggest after you clean them, powder coat them to protect them.
  6. Raptorguy21
    Raptorguy21 The Bob Vila of Trucks
    34
    864
    26
    Jul 7, 2010
    Hell Paso
    Have you stripped some of the threads on the wheel?
  7. kendasf
    kendasf Member
    33
    Apr 13, 2011
    Garland, Tx
  8. tnsbruce
    55
    Feb 6, 2011
    The shop that mounted the tires stripped a couple - I used helicoil to repair. Ideally, I think these wells should come with helicoils standard for a more secure mounting of beadlock ring.
  9. WSI
    WSI Supporting Vendor Supporting Vendor Supporting Member
    1,505
    968
    Jan 15, 2012
    Kansas City
    You can try clear coating the bolt heads. That's what i do when I want to keep the grade 8 finish.
  10. treypal
    treypal Lord of the Raptors Supporting Member
    37
    4,452
    4,072
    Jun 16, 2011
    Riviera TX
    Beadlocks strip out, back out and break bolts all the time. I seriously don't suggest them.
Share This Page
