GEN 1 King 30001-401 vs 30001-407? ?
Discussion in 'Ford Raptor Suspension Discussion and Modification' started by oplersx, May 22, 2020.
Fox - Redefining Ride Dynamics
  1. oplersx
    oplersx Full Access Member
    385
    100
    Feb 11, 2014
    British Columbia
    I found two part number on King 3.0 front coilovers. Only 30001-401 is listed on King's website. Are there really two versions avaiable?
  2. SKS
    SKS Full Access Member
    119
    41
    Sep 7, 2019
    CA
    Not sure if King changed part numbers, but I recently placed an order and this is what I was sent last week.
  3. Canuck714
    Canuck714 Full Access Member
    552
    259
    Jun 11, 2012
    San Antonio TX
    Finned Resi with clickers VS smooth body Resi Im guessing.
    Does anyone know if the new 3.0 IBP coil over is made for the Gen 1 now?
  4. oplersx
    385
    100
    Feb 11, 2014
    British Columbia
    Down to FOX or ICON now... KING shines more on off-road from all the info i read. I need one that rides better on-road.
  5. Canuck714
    552
    259
    Jun 11, 2012
    San Antonio TX
    I have the 3.0 FOX with DSC. Works good and the clickers let you dial in the feel you want. On the street you will want the Hi and Low speed almost all the way open (Soft)
  6. Michael Rodriguez
    Michael Rodriguez FRF Supporting Member Supporting Member
    9
    Aug 18, 2019
    Buda, TX
    I’m pretty sure they changed part numbers. The RF at the end designates reservoir fin. You could buy a 30001-401 or a 30001-401f. Not sure what the difference in a 401 vs 407 is. Went through this when I was looking at 3.0s. Went with Fox so it didn’t matter.
  7. oplersx
    385
    100
    Feb 11, 2014
    British Columbia
    LOL.. that's what I am about to do. KING is kinda confusing... besides from all the readings I had, looks like FOX will be the most comfort one on road. The off road I do, any of those 3 big names would be more than enough so I probably won't feel any differences off road.
  8. SKS
    119
    41
    Sep 7, 2019
    CA
    Spoke with someone at King, they changed the part number. I was also informed that they changed the mounting process to make the install easier, compared to the way the 30001-401 had to be installed.
Share This Page
