AFCO's 2010-2014 Ford F-150 Raptor Heat Exchanger and Pro Series Heat exchanger with Dual Cooling Fans!!
AFCO Racing Products is proud to announce the launch of our new Heat Exchanger for the 2010 & Up Supercharged F-150/Raptor. Reduce coolant temperatures up to 30°F and unlock the full potential of your F-150/Raptor with a fast 1-2 hour installation time.
The 80284NDP is over 3 times thicker than other Heat Exchangers. The 80284 offers increased surface area, volume, and a double pass design (uses a baffle to pass the coolant through the core twice) to help reduce coolant temperatures by as much as 30°F!!!
The 80284PRO comes with the dual fans which adds over 1600 CFM of constant airflow (800 CFM per fan) to reduce heat soak when there is reduced air flow through the heat exchanger.
These heat exchangers will fit Roush or Whipple supercharger kits. Whipple installations require extra mounting brackets.
Details:
Core utilizes 2 rows of 1.00” tubes – 3 times thicker than most competitors.
Can be installed in approximately 1-2 hours.
Dual 10” SPAL fans that pull 800 CFM each – helps prevent heat soak (80284PRO only).
Dual relay wiring harness (80284PRO only) with detailed instructions for easy installation.
Fits Roush or Whipple supercharger kits.
Fits ’10 & Up Ford Raptor and F150.
Drops coolant temps 30° F.
CALL US TODAY FOR QUESTIONS OR TO PLACE AN ORDER! 732-780-0770 or Email [email protected]. THE SUMMER IS COMING, HELP KEEP YOUR TRUCK COOL!
80284NDP - $461.99
80284PRO - $799.00
Details:
80284NDP - $461.99
80284PRO - $799.00
