KC Hilites Flex LED Install
Discussion in 'Ford Raptor Lighting Modifications Forum [GEN 1]' started by KaiserM715, Apr 1, 2015.
Sponsored By: KC HiLiTES
  1. KaiserM715
    KaiserM715 Kaiser Söze Staff Member
    8,580
    3,082
    Aug 5, 2010
    Since I was going to change up my front bumper, I wanted to try some new lighting as well. I was given the chance to get some of the first sets of the KC Hilites Flex LEDs.
    Flex LED lights and LED light bars for Off road UTV, ATV and Trucks | KC HiLiTES
    The setup that I am running is a 30” combo bar and the two duals on Switch #1 and a 30” spot bar on switch #2.
    The really cool thing about these lights is how modular they are. For the bars, they come in 10” segments and you can mix and match them to get the combination you want. The 30” bars I am running are made up of 3 10” bars each. For the combo bar, each segment has three spot lenses and two flood lenses. Given that the lenses are much larger than what you normally see on a light bar, I am expecting them to have a much better beam pattern than typical. Each LED is 10W.
    [​IMG]
    [​IMG]
    Each segment attaches to the next using a small bus bar for the ground, a wire for the hot and then a thick, aluminum structural link.
    [​IMG]
    The duals are both flood pattern and use all of the same wiring connections that the 10”+ bars use.
    [​IMG]
    [​IMG]
    [​IMG]
    I also used this as a chance to make some improvements to my under-hood wiring. All of the wires to the upfitters have extensions soldered on that lead to WeatherPack connectors. This allows me to switch things around in seconds, if I want to. I had been wanting to do this for a while and this was my chance. I labeled each one of the connectors with the corresponding switch number. I put heat shrink on the end of the wire for #4 as I am not currently using it and will add the connector when it is needed.
    [​IMG]
    The one downside to going to an aftermarket bumper is that you lose all of the support structure of the OEM bumper, which is very handy for running light wires. My solution was to use all weather zip tie pads with double sided tape. The wire harness is then zip tied to the pad.
    [​IMG]
    I also added a padded p-clamp to the bolt I used to attach the valance support.
    [​IMG]
    [​IMG]
    [​IMG]
    Bumper install
    www.fordraptorforum.com/f11/lge-cts-front-bumper-install-41813/
    Here are some crappy pics from my cell phone showing the light output. It is truly difficult to get a good picture of how bright these are. The darkest place I knew of is the parking lot of a nearby park (not a whole lot of truly dark places in my area).
    Here is a shot of the headlights only (halogen):
    [​IMG]
    Here is a picture of the combo bar and duals:
    [​IMG]
    Here is picture of the spot bar:
    [​IMG]
    Here is a picture of both of them (headlights are off in this pic – they made no difference with everything on):
    [FONT=&quot][​IMG][/FONT]
  2. puddle hunter
    puddle hunter Full Access Member
    790
    500
    Mar 3, 2011
    Stockton, CA
    Good lord that's a lot of KC power!! Looks great, can't wait to see the output pics.
  3. dkfc13
    dkfc13 Full Access Member
    726
    265
    May 13, 2013
    SE Michigan
    Love the weatherpack idea!! Dont know why I havent already done this.
  4. Taxman
    Taxman Full Access Member
    385
    306
    Aug 14, 2014
    Raleigh, NC
    Very sexy.
  5. Yukon Joe
    Yukon Joe FRF Addict
    40
    18,308
    11,562
    Nov 16, 2011
    Oak Island, NC
    Jimbo likes this.
  6. 14truckie
    14truckie Full Access Member
    40
    58
    20
    Sep 4, 2014
    East Bridgewater
    Nice definitely need pics
  7. demnraptor
    demnraptor Full Access Member
    30
    106
    17
    Oct 7, 2013
    Humble, TX
    Very nice anxious to see output!
  8. Floyd91
    Floyd91 Full Access Member
    316
    192
    Oct 10, 2014
    Those flex lites have really piqued my curiosity. Can't wait to see some night shots. What connectors did you use?
  9. KaiserM715
    8,580
    3,082
    Aug 5, 2010
    First post updated with night pics.
    The lights came with wiring harnesses. The connections to the lights and the harnesses is a Deutsch style connector. I used WeatherPacks to connect the wiring to the upfitter pigtails near the firewall.
    In general, I prefer the Deutcsh style, but a kit of WeatherPacks was more in my price range. They are both good connectors, the WeatherPacks are just a little more bulky.
  10. Jimbo
    Jimbo Mad Frog Mattis
    12,603
    8,863
    Sep 17, 2014
    IL
    Looks good, just a little fine tweaking and you should be good. I still have to adjust mine... but I've been lazy - they're almost in the right spots, lol.
Share This Page
