Just purchased a raptor cv and suspension questions
MD
Hey guys I’m new to the forum. I have tried searching but haven’t found any solid information. I’ve had the Raptor for about 3 days now. I am not sure if it is at stock height. The previous owner I assume sold the Raptor rims and put 20 inch ford rims on it. I will need multiple things to pass the MD safety inspection. Right now it’s making a banging sound from the driver-side front wheel. When looking at it I realized the CV axle is banging in and out when driving. I’m attaching some pictures. I can pull the CV axle up and it makes a metal-on-metal bang every time. Any info on if the height looks stock or what has been modified would be great. I’m not new to trucks or working on trucks but I am very new to the Raptor. Always liked them and just found the opportunity to purchase. Thank you for all of your help.
Matt.
Ricoman
Well-Known Member
WASHINGTON STATE
Im no expert,but judging from all that grease you need to start with new CVC joints.;)
Congrats on your new Raptor,your going to love it.....
I'm shopping for new tires now,and came across this article that might be of some help to you.
Good Luck!
Bigt3141
Tucson
Would need to see pictures of the front and rear suspension but it looks like they put a leveling kit in.
W0n70n
C Springs, CO
The bottom of that front coilover looks like a Fox 3.0 and the preload is adjustable so they probably have it adjusted to level the front, I have those on mine and I don't chew through CVs super quickly or anything, it's not a large change like a traditional lift like on other trucks. Since it's level with the 3.0s (I'm assuming) on the front there's a very good chance the rear leaf springs have been changed, if it's more than 2 fat leafs then that's a good sign it's on deavers or icons (probably deaver since fox up front), check the rear shocks as well, if you see external bypass tubes then congrats, it's a pretty good setup you've got out of the gate.
I can't wait to see what it looks like with appropriate wheels and tires again though, I don't think I've ever seen a raptor on normal f150 wheels and tires and I hate it lol. My truck is on 17x8.5 zero offset (4.5 backspace) on 37x12.5s but my front fenders are +2+2s with the fenderwells and pinch welds folded over. You can run a zero offset rim on the 35s without any other changes needed.
I almost forgot, check the vacuum lines to the IWEs on the fronts to make sure that system is functional, it could be partially engaging and causing the CVs to wear out from the shock load of engaging and disengaging etc, if it's partially working, just remove the lines and cap the vacuum port on the hub until you either delete the IWEs or repair the system, it's better to leave them fully engaged than leaking halfway.
TomDirt
Hesperia CA
capsosravens35
MD
Thank you everyone. I didn’t see any of these responses. I have a lot to address but that’s the fun of starting over and getting to do what you want. I have a reason to fix it. I’ll update and answer questions tomorrow and probably have some more.
capsosravens35
MD
Let me ask this. I’m not new to the 12th gen F150 but I am to the raptor. Obviously most parts are specific to the raptor stock and not compatible with the stock f150. I found in the past most OEM parts were better verse a lot of after market. Do you think that’s the case on things like CV axles? Ball joints, tie rods? I use to be a huge advance auto guy, Napa, car quest, and sometimes auto zone. But I started getting into buy OEM from Ford. Just wondering opinions on this. Thanks.
Bozz
Royal Smart A$$
Nashville, TN
I got my entire front end parts from Rock Auto. UCA's, tie rods, LCA's, CV Axles, etc., etc. I didn't want to mess with ball joints, so I just ordered new parts for slightly more than ball joints would have been and a LOT LESS hassle.
TomDirt
Hesperia CA
I looked at it differently. Because FoMoCo didn't want to spend a billion to redesign everything, so they kinda stretched the regular F150 parts. Front tie rods and cv axles, rear axle housing & axles are just longer, but use the same bearings. Other items were upgraded, like a thicker swaybar. IIRC the rear driveshaft U joints on my 2011 SVT Screw are bigger than my 2012 Ecoboost SCREW andd the rear leaf springs seem to have a slightly softer spring rate. The cast steel steering SVT knuckles are (allegedly) stronger than regular F150 units too. Even minor items like the spare tire hoist crank dealio thing (under the bed) is different. I ordered a new one for my ecoboost and it doesn't fit on the SVT frame
TomDirt
Hesperia CA
Both stock F150's and Raptors fail when it comes to brakes, however.
The brake pads & rotors on a 4700 lb shortbed standard cab 2WD V6 (302hp/278lb-ft) with 235/75/17 tires, (30.9") are the same as on the 3 ton SVT crewcab 6.2l V8 (411hp/434lb-ft) on 35's. Make that make sense.
capsosravens35
MD
What I failed inspection was the left cv axel. I knew that needed to be replaced. They said the brakes front and rear are locked up and may need need new pads, rotors and calipers. I thought about greasing the calipers and rebuilding them but I just decides to buy all new. The e brake needs new shoes. Tires need to be replaced which makes me decide do I find raptor rims or some other bead locks. Do I go to a 17 or a 20? Steering rack bellow boots. 3rd rear brake light they said wasn't working. But it seemed to be when I checked it. Inner right tie rod. All in all is mainly what I figured. I wanted to change the tires. I figured the brakes would need to be replaced soon minus the calipers. While the prices are insane for the raptor parts, none of it is to crazy. Rock auto by the way is great. I probably should have ordered everything from them.
capsosravens35
MD
I have 275/55/20 ford rims that were on it when I bought the vehicle and not the stock 325/79/17. That's the other decision on rims and tires.
101,289
60,424
HC FabWerks
