Just mounted Toyo AT 3's
Discussion in 'Ford Raptor Suspension Discussion and Modification' started by Cornwallis, May 19, 2020.
  1. RotorHead695
    RotorHead695 Full Access Member
    239
    149
    Mar 25, 2019
    Molalla, OR
    Yeah...going from a C rated to E rated tire will be noticeable for sure. I run D rated on mine, it's a nice middle ground.
  2. Bowewelding
    Bowewelding Full Access Member
    199
    41
    Aug 13, 2017
    I rock the toyo at 2s, love those tires..i can't wait to try the 3s are they 10 ply tires? Thats why mine ride a bit stiffer than the stock bfgs at 8 ply
  3. Cornwallis
    Cornwallis Full Access Member
    125
    59
    Apr 13, 2020
    L.A.
    I lowered the pressure down to about 33 now and it made an improvement. But it's still more stiff...plus I've got a light shimmy at speed so I need to rebalance them and then I'll reassess.
    RotorHead695 likes this.
  4. Cornwallis
    125
    59
    Apr 13, 2020
    L.A.
    Not sure on the ply count, I didn't look specifically on their site.
  5. Bowewelding
    199
    41
    Aug 13, 2017
    Run balance beads!! Ever since I tried them I'm hooked..way more accurate than a balance machine thats "calibrated" and even then it has a high school kid operating it..lol..the beads do a perfect balance every time u drive, even as the tire wears, no need for a rebalance.. and no need for sticky weights that potentially fly off..our size tires take 8oz (35×12.50×17)
    BenBB likes this.
  6. SS308
    SS308 FRF Supporting Member Supporting Member
    778
    404
    Dec 31, 2018
    Cheyenne, Wyoming
    I know! I would almost buy one...LOL!
  7. Cornwallis
    125
    59
    Apr 13, 2020
    L.A.
    Yeah, beads are interesting. I used them years ago but wasn't in love. I'm not opposed to trying them again...I take it you had good results?
  8. Bowewelding
    199
    41
    Aug 13, 2017
    I run them in every tire i own..the only time I had trouble was not running the correct weight of beads..i use airsoft bb's now days..i mount and dismount my own tires tho..tire shops will push using a bag of beads and I don't think that is as accurate as loose beads being able to spread out
    Cornwallis likes this.
  9. termite352
    termite352 FRF Supporting Member Supporting Member
    93
    55
    Apr 16, 2018
    Venice, Florida
    I recently put the new A/T III’s on my sled. Definitely a stiffer ride but it’s also very comfortable. I think airing it down a little will help to lessen the stiffness. My setup is 35/12.5 R20 and I love the look. Loving the A/T III
    GR8Ride likes this.
  10. Raptor50
    Raptor50 Full Access Member
    76
    57
    Feb 9, 2014
    CO
    Termite352, after running the AT3's would you buy them again over the KO2's? I just ordered a set of Velgens and torn between KO2's or the Toyo AT3's in 35/12.5 R20
Share This Page
