GEN 2 Just gave up trying to run wire to S1 backup lights from engine compartment
Palmetto_Raptor
South Carolina
Spent 2 hours rolling around under my 2019 Raptor truck this morning trying to find a clean way of running wire from Baja Designs S1 backup lights that I currently have tapped into passenger side rear tail light. I got the harness that also allows you to run them off one of the upfitter switches but that requires running a wire under the truck from the back passenger side to the front passenger side.
I just don't see any clean way to do this and I can't find an pics showing the path to run a wire from under the truck.
Does anyone have pics showing the best path for running a wire from the back of the truck to the passenger side of the engine compartment?
I'm familiar with frame clips but I don't even see good places to put them and I would really rather have the wires up higher than on the side of the frame.
Starting at the back of the truck I see some thin metal cross 'U' channel beams that run from the left to right side and support the bed of the truck. These have a few holes in them. And would be a good place for the wire because they are way up high. I could drill another small hole next to the factory holes (about the size of a dime) and loop a wire tie thru them to hold up the wire? But that's not really a professional solution and that will only get me part of the way.
How are people running a wire from the back bumper to the engine compartment?
Refugio
South Texas
Run it thru the passenger side frame.
That’s how I ran mine. Thru the frame and not next to it.
A fish tape is a must.
Go in from just behind front tire and pull the wires from the back to the front up to where the uplift wires are for power.
Zip tie extra wire at the back and stuff that into the frame also.
Easy
Palmetto_Raptor
Palmetto_Raptor
South Carolina
Easy
OK... I got a couple 10' Baja Designs extension wires. These are in a heavy sheath and have Weather Pack plugs on both ends. Were you pulling regular double strand wire and then adding the Weather pack connectors later? What gauge wire did you use?
You ran a fish tape thru the frame all the way from the front of the truck to the back in one pull? Or did you go into holes in the frame and pull a little at a time?
Thanks!
Yeah, what he said.
I didn’t route through the frame, I just ran along the frame, being mindful of possible contact points. It’s time consuming, but not difficult. You’re in SC, so it --can’t-- be that cold :)
Mine goes down from the upfitter area, zip tie loosely around a convenient frame to harness connector, over near the wheel well plastic. Gorilla tape to a 2nd nearby harness, an repeat the process down along the frame. If you’re exceedingly cautious, run some wire loom as well.
I’d say it’s a 2 pint job. Time on the ground under a vehicle is expensive, consuming ~ 2x the amount of beer.
MnFlyer
MN
Beer? You gotta up your rates man. Scotch is there going rate these days.
dewalt
Double insulated wire and you do not need a fish to run in frame
4x4TruckLEDs.com
What everybody else said. Come down from your engine by the wheel area (zip tie it out of the way). And then into the passenger side frame rail. Feed it along that to the back where you can exit and go right up. Nice and easy.
Not sure which harness you are using but our Upfitter Control Harness is 1 solid piece and we give you a good length for this purpose (to route it around things): http://www.4x4truckleds.com/crystal...ness-for-2017-ford-raptor-s1-s2-reverse-kits/
pastorwug
Santa Maria, CA
One more vote for fishing the harness down the frame rail, it took me some time, and I used a fish tape, and worked out really well in the end.
4x4TruckLEDs.com
Man Law: it’s only acceptable to drink scotch if there’s no bourbon readily available :p
Aren't they technically the same thing? Only Scotch is FROM Scotland, and Whiskey is from Ireland (or TN?). Everywhere else it's bourbon? Something like that?
