JLT Oil Catch & Questions
Jkysh
Morning all,
Have a few questions regarding the JLT oil catch can, and a few accompanying mods I am looking at before winter comes around.
Looking at the JLT oil catch can linked below, pictures look to be different PCV routing set up than the previous versions I've seen, the ones that rest on your guy's coil packs. Will this part below fit my 6.2, and if so will it come with the bracket to mount to my firewall as seen in the pictures below?
Im looking to snap this into place soon as I'm changing my oil in the next 500 miles.Thinking it is just an updated version but looking for confirmation
https://www.stage3motorsports.com/JLTOSP-F1506210-2010-2014-SVT-Raptor-62L-JLT-Oil-Separator.html
In terms of intake options and pedal commander, I'm sure there are threads which I will look at shortly. However, what is the general consensus on these parts? Not quite sure my 6.2 needs a cold air, I currently have a KN panel filter in the stock box, but I'm toying with the idea.
Regarding pedal commander - any negatives to adding this little part that seems to pack a lot of bang in th long term?
Looking to throw these parts on with perhaps an exhaust upgrade prior to winter rolling around in new england. Thank you all
Tx State
Well-Known Member
That is the exact catch can I got and I also ordered it from them as well. It fits your 6.2 and comes with a firewall bracket to keep it out of the way of everything.
Swacer_2
PA
I have this catch can as well. Was a very quick install. Only concern I have is that the tubing does not have any insulation on it unlike the factory line. I may look to add some at a later date.
J
Jkysh
Thanks for the follow ups. I ordered this the day I posted and installed.
Fast, factory fit and hell of peace of mind. Caught enough in about 200 miles to justify its purchase. Very pleased
mpk1996
Well-Known Member
I did both sides. Periodically check them. The last check the passenger side had 5/8" of oil depth in it, the drivers side was bone dry.
I did both. Passenger side gets a little oil, the drivers was always dry so I removed it. I’d say you only need the passenger side.
thanks guys. thats what i wanted to know. i guess i'll only get the pass side.
mpk1996
Well-Known Member
got the catch can. boy, the new setup is a super easy install. its like a 5 min job, seriously. i was do for an oil change. did that today, so we'll see how it looks in a month or so
Grassraptor
Louisiana
Don’t wanna sound dumb but was is the purpose of the catch can? New to the raptor world and this sight is very informative!!
mpk1996
Well-Known Member
it goes between the valve cover and the intake. the reason the hose is there is to releave crank case pressure. you also have oil vapor above the head/valve train and that vapor gets pulled through that vacuum line back into the intake, therefore getting burned. not as good as clean air and fuel vapor obviously. so, the catch can separates out that oil vapor so it doesn't go back into the combustion side of the engine. this holds true for any vehicle with that type of setup
101,126
60,302
osvariitoreyes
