JL Audio VX600.2 random issues
dday
Shawnee KS
Hey all,
dealing with a head scratcher. I have a 23 F-150 Raptor with (formerly) B&O stereo. System details NavTv sourcing everything from factory HU, JL Audio VX600.6 running 3.5inch Focal K2 WM, 1" K2 tweeters and rear 6.5in Focal flax coax. Front doors are K2 Power 2ohm 6.5 on a JL Audio 600.2 both amps connected by a JL Hub, subs are 2 8W7's on a JL 1200 HD, not connected to the hub.
Power is Kicker OFC 1/0 both power and ground ran to the battery broken out in the back with a distro block with 8awg feeders to amps.
Voltage with the truck off at the distro block is 14.7 (no music playing). Over the last month or so I've had a few weird issues, one being random sub pop, doesn't happen 99% of the time very random. Another time I got in the truck and no audio, amps were on, just no audio, door chimes and other truck sounds worked, 30 min later everything worked fine. Now today I get in, everything works, run an errand get back in no door speakers, come home troubleshoot, 600.2 isn't on. Meter voltage at block 14.7 before the fuse, check voltage at amp plug 13.8 and solid remote 14.7. Tinker with wires, shut off truck and allow it to go to sleep, open the door and notice the 600.2 blinks blue twice and shuts off. Get frustrated and start googling things, come back later and 600.2 is on and playing.
Few hours later need to run another errand, no door speakers, amps off, get back in 45 min later and everything's fine.
The only odd thing I'm seeing is when I measure voltage before the fuse on this specific amp i'm getting 14.7 but after the fuse it's 13.8, none of the other fuses are doing that, I will swap the fuse just kind of over it for the day.
Another less than ideal thing is the 600.6 uses the navtv remote, the 600.2 uses the remote out from the 600.6 and the 1200 uses the remote out from the 600.2 daisy chained if you will instead of the 2 slave amps using the 600.6's remote, I'll correct that when it's warmer.
Regardless, I hope this 600.2 isn't crapping out, I got in new in November'ish even though they're discontinued, it had clearly been sitting in a backroom for awhile.
Any suggestions? I cannot find any obvious wiring issues, all connections are ferruled and heat shrunk, the speaker splices are bullets I plan to soldier this summer after my next upgrade, otherwise there is nothing physically wrong that I'm seeing, just that amp not coming on properly.
The Car Stereo Company
here, on frf
so the issue is with just the front door woofers? subwoofer works? a voltage drop after the fuse is usually a bad fuse or bad connection/corrosion with the power wires.
Welcome to FRF.
I didn’t know you could have all those fancy audio components in a prius.
The scenario changes here, one time the amp is on and you have no sound, another time the amp is off. I’d look hard at the ‘harness’ connections, in addition to the power. I had something similar when I pulled the wiring of my DSR, reseated but didn’t seat the connector fully.
I’ve also had some scramming issues before turning off the auto stop/start. I’d have good, 13+ volts but when the starter kicks in it would drop to the low 10’s, enough to scram the amp briefly and recover. I disabled that “feature” and moved on.
dday
Shawnee KS
Welcome to FRF.
Thanks Smurf
Yes the issue does seem to change which is why I’m scratching my head.
I’m going to dig into some today once it warms up. I plan to replace the fuse, correct the remote wire daisy chain and check the harness.
Speaking of auto start, being winter in Kansas I’m doing a lot of that, I have noticed everything seems fine if it’s already running I’m going to pay closer attention now.
Thanks
dday
Shawnee KS
Not sure where my reply from last night went.
The issue is with the front door amp/speakers, I assume the subs would work if the remote to that amp wasn’t from the amp having issues. I’m going to correct that today.
No corrosion I’m finding, everything looks new. I’ll replace the fuse today as well.
Thanks
dday
Shawnee KS
Ok I can admit when I'm a total *******, so here goes. The lug to the fuse had walked loose, the way the block is mounted on the back wall you couldn't tell even when I was using the probe to check voltage it didn't move. Soon as I put the allen wrench on it, you could tell. I replaced the fuse anyway but I'm not going to touch anything else for a bit to see if that was the entire issue, I doubt it. Go ahead bust my balls for missing such a stupid little issue, especially after all the other troubleshooting I did, how do you miss the simplest thing.
:snoopfacepalm:
:snoopfacepalm:
Ask and ye shall receive:
Glad you got that prius sound system fixed!
greatone99
ma
MAKE sure nav tv is up to date on software ,mine did something like this a few years ago. The nav tv would randomly reboot
dday
Shawnee KS
I wondered about that. I’ll check the software if the problem comes back.
I’ve been in it twice since I found the loose lug. Thanks
