SilverGen1
Well I had got the trekkmotive from rock auto and not even 2wks after installing everything including the iwe deletes, is it's sitting in front of my friends house 2hrs away from me with both (diff side) cv's broken and gone. No hard Off-Roading just driving it around to find any issues with the truck since I put them on along with a set of Carbon Shock Tech c/o's. So went to go to home depot (2hrs from my town) last night and about half way to home depot, it starts to dump snow, so i made sure i was below 45mph (35mph) and switched to 4 wheel high and did great... out of the snow i switched back to 2wd and about 20miles later on the fwy it felt like a flat tire, followed by grinding and something coming off the truck. We'll i pull over and check it out and find the passenger side axle Is steaming and busted. Limped to by friends house and now can't source a trailer wide enough to get my truck back home (92inches wide). Today brought my trailer and stock f150 wheels in hopes to get it on the trailer which is 84inches wide between fenders and while changing the drivers Side wheel, I noticed that the drivers Side was busted as well. So I don't know what caused this to happen. Cause I got those axles for the fact of extended travel. Shafts ard nice and beefy but just not sure about why this happened.
So a quick thought... (question),
With the iwe delete... does the truck need to be stopped to put it in 4wd high, like when shifting into 4wd low? Or can you still engage 4wd at speeds upto 45mph?
