Ok members I have seen a lot of good intel on this forum to help with issues. I am hoping to pick up some insights to TWO issues that I am having before I lose it and go postal on SPF here in Plano, TX.
I have a Gen 1 (2010) 6.2L with just under 80K on the clock. I purchased this truck brand new and immediately installed:
>ARH LTH, HFCs w/Magnaflow exhaust system
>Bully Dog Cold Air Intake (this gets rid of the intake resonator box off the throttle body)
>Tune from Hennessey Performance (with the capability to switch back to stock tuning)
Every year I would switch back to stock tune drive for maybe 100 miles and go inspect. No issues. UNTIL this year... It doesn't want to reset the O2 sensors to ready and I have even paid the Ford dealer to flash back to stock ($140). 1000 miles later still no reset.
Had all the plugs replaced and the lower/Non-heated O2 sensors as well. In hopes that this would at least get me to only one "Not ready" and get through inspection... Same issue after 125 miles.
To add insult to injury, the dealer dinged my hood and somehow managed to make my Raptor Retrofit HIDs not work when they worked fine when I brought it in. The Halos around the main projectors work, but the main lights are out regardless of switch position. I think they disconnected the battery working on the o2 sensors without checking to see if the switch was in auto on position.
I have tried:
bulb replacement
checked fuses & power supply
checked ballast and ignitor (I have spares)
Relay box
These lights have always been a little finicky, but are well worth the nighttime vision improvement.
Sorry for being so long-winded, but I have been going back and forth with the dealer on this since before Xmas. Thanks!
I have tried:
bulb replacement
Relay box
