Is this a ticking sound normal?
2020FordRaptor
Nevada
Hello everyone:
So upon cold starts, our 2020 Raptor makes this ticking sound. Probably as loud as the warning chimes (sorry I don't know exactly to compare it to) and was wondering if this is normal. I'm probably just being paranoid but better to check then to not. The vehicle is completely stock. I don't remember it having this noise when we got it new. @FordTechOne can you help with this at all?
Thanks!
Edit: after further research and numerous YouTube videos, I can say that the sound O believe is wastegate rattle
  • 20221009_101559~4.mp4
    13.1 MB
Snuggles
Portland, OR
I can’t hear anything unusual, but these engines are known to develop cam phaser issues, which presents itself as a rattle on cold starts. It typically goes away once oil pressure builds.
The way to test this is:
- next time you are doing a cold start
- before starting the engine push the gas pedal to the floor and hold it there while also pressing the brake pedal. Hold them there.
- Attempt to start the engine while still holding the pedals down. The engine should cranks but not start. Do this two times for about ten seconds each, then immediately start the engine as normal.
If there is no rattle when it starts this time then you likely have a cam phaser issue.
The turning over will build oil pressure, which actuates the cam phasers early.
Cam phasers can get so bad they no longer function and rattle constantly. But I’ve seen this test done on YouTube (while I was researching a turbo issue).
2020FordRaptor
2020FordRaptor
Nevada
Wouldn't that rev the engine? That is horrible on a cold engine.
HighwaySentinel
︻デ┳═ー - - - - - - -
California
This will also give you 30 extra lives. Pew pew
