Looking for the best price on powered running boards? We've got forum member discounts for your Ionic Electric Running Boards!
Forum members are locking these in for under $1000 before sales tax!
Getting in and out of your Raptor is easier with Ionic Electric Running Boards. They automatically deploy when the door opens and retract when closed, giving you a step when you need it and a clean, low-profile look when you don’t.
The Ionic Electric Running Boards are designed to fit your Ford using a vehicle specific hardware kit to mount the steps directly to factory mounting points.
- Electric-powered side steps automatically deploy and retract when opening and closing vehicle doors
- High-strength aluminum construction supports up to 600 lbs. per side (for 4 door-vehicle)
- Powerful dual-motor technology comes standard for reliable performance in extreme climates and weather
- Equipped with easy-to-install, magnetically activated door switches that leave the OBD2 port free for other accessories
- Durable 6” wide board features an advanced anti-slip texture creating a secure, stable stepping surface in any weather
- Integrated safety-stop system automatically engages if an obstruction is detected in the running board’s path
- Retracted running boards provide optimal ground clearance and protects rocker panel while preserving the look of your vehicle
- Limited 1-year warranty
You could be out on the trails, loading up the family, or just cruising through town, the Ionic Electric Running Boards are a practical and stylish step for any place your truck takes you!
These are a fit for:
2017-2026 Ford F150 Raptor SuperCrew
Reach out to me directly and I’ll walk you through options, confirm fitment, get your order submitted with priority, and provide forum member pricing! I’ll personally see you through every step of the way!
DM me and I’ll get you a quote and make sure your Ionic Electric Running Boards are still in stock!
