GEN 2 Intercooler or radiator first?
Discussion in 'Ford F-150 Raptor General Discussions [GEN 2]' started by hedonist222, Feb 14, 2020.
  1. Truckasaurus
    Truckasaurus Full Access Member
    223
    73
    Jan 9, 2020
    NE
    Intercooler first because even in "normal" climates the Gen 2 heat soaks pretty bad but if you are planning to run it hard in the dunes in the UAE heat then you should definitely put a larger radiator in it.
    Heat is the enemy of any high performance vehicle.
    I would also look into transmission cooling upgrades.
  2. zhengyucoo
    zhengyucoo Member
    42
    7
    May 19, 2017
    Atlanta
    Compare to before radiator and thermostat installed, which is around the same without them.
  3. jabroni619
    jabroni619 FRF Addict
    1,635
    942
    Jun 13, 2017
    So hot compared to itself, but not really "hot" because it's actually the same?
  4. zhengyucoo
    zhengyucoo Member
    42
    7
    May 19, 2017
    Atlanta
    Correct, it is still running around the same temp compare to stock when normal driving, but I do feel after letting off the throttle the coolant temp drop faster. At WOT situations there's is a big difference, the temperature stays put instead of raising unlike driving in 10th gear.
    As far as the intercooler goes, I'm running the Garrett intercooler, the charged air temp is pretty decent, it actually keep temperature within 20 degrees of ambient even at wot.
  5. 454 Motorsports
    454 Motorsports Member
    50
    48
    79
    Jun 4, 2017
    What are the risks with warranty? My local dealer told me if I change my intercooler, and had a failure, for example blew a turbo, that they wouldn’t cover it. Normally this stuff doesn’t bother me, but after being turned away for a cracked diff because of my aftermarket suspension, I’m now hesitant.
  6. jabroni619
    1,635
    942
    Jun 13, 2017
    They would be well within their right to void turbo warranty with an IC swap
  7. zhengyucoo
    zhengyucoo Member
    42
    7
    May 19, 2017
    Atlanta
    If it breaks it breaks. If you worry about any warranty, dont change anything on the car, they can always find excuses not covering you. My steering wheel is peeling and the heating wires are showing on the wheel under the leather, ford is not covering it, my springs were sagging, not covered, at that point I figured Ford got the warranty I cannot trust. May as well do whatever you want to it.
    Had two ford before, never had any luck with warranty work, it's just not bumper to bumper like some other car company.
  8. nikhsub1
    nikhsub1 FRF Addict
    1,414
    807
    Mar 5, 2017
    Stacking radiators is not an issue. FMIC in hot climate is ideal - the radiator not getting enough air or getting 'heated air' from the IC are non issues.
    Obviously not - they went with the option of 'barely enough to get by'. The stock IC is absolute garbage. It is woefully undersized and made of shit materials. Your truck heat soaks instantly with that POS.
  9. Badgertits
    Badgertits Full Access Member
    941
    503
    Jan 24, 2019
    Ma
    I agree w/ 2nd statement first not so much. Just don’t see how it WOULDN’T effect airflow/cooling ability of the radiator & besides anytime you cramp the engine bay further it’s going to be tougher to extract heat. For me The other thing that I don’t like about em is they immediately cause you to tamper w/ other systems like the grill shutters & possibly sensors in the grill/bumper correct? Like ambient temp or the active cruise stuff?
    then there’s the fact that while the dealers/techs may not always be the sharpest if there’s ONE thing the raises the red “modded flag” on a turbo vehicle it’s that universally recognized giant “COBB” IC smiling @ ya through the grill. Even if you’re not tuned- they’ll assume you are/were regardless what you say. And speaking of that, isn’t it also kinda sorta the case you may NEED a tune to run properly & prevent codes w/ a large FMIC - and some CAIs as well?
    that’s why I just think if you’re going to upgrade the IC sticking w/ a stock mount one like mishimoto/Wagner/Garrett/CVF/whipple etc is a safer bet. Not like you don’t have choices. Aside from the fact I think Ford would have a tough time blaming a stock mounted replacement IC on warranty denial when it requires Zero modification of the vehicle & functions/fits as stock just better flowing.....I also think many dealers wouldn’t even freaking notice it unless they were specifically working on something there & related to it
  10. nikhsub1
    nikhsub1 FRF Addict
    1,414
    807
    Mar 5, 2017
    You can not agree all you want, the facts are stacking is a non issue. Been tested and proven. As for your point of an IC in the stock location - I don't think it gets enough air in there, why do you think Ford had to put fans on the intercooler? I've never seen fans on an intercooler before in my life. Also, if Ford wants to void the warranty related to an aftermarket IC, it isn't going to matter where it is.
Share This Page
