Todd Turbo S
Installed Radium Engineering Dual Catch Can. First off, great product, high quality and thank you to Roman with NEO-Garage for the competitive pricing.
Only one negative comment, installation instructions are the worst I’ve seen, but their live tech support is superior to others I’ve experienced. If you can follow the instructions, they instruct you to install one catch can at a time, then you need to undo some of the installation in order to get the other can and bracket installed, makes no sense. A bit of a learning curve towards the last two steps in how to position the hoses in order to get a wrench on them to tighten. Also, instructions call for 14 torque bracket bolt to 14lbs, unless there’s a smaller special torque wrench, no way to get this accomplished.
If anyone decides on this product, be carful tightening the green and black locking nuts, they will scratch easy. I ended up applying blue tape before tightening.
overall, very pleased with the product, quality, fit and finish and the Aesthetics.
