Installed CAI and got two fault codes
SexyAvalancheGrey
I installed a CAI a few days ago and got these two codes tonight:
P061A - Internal Control Module Torque PErformance
P04DB
Seems to be directly related to the CAI after my research. Seeing if anyone else had this happen and did they find a way to fix the issue or should I just cut my losses and put back the stock airbox?
joegie
North San Diego
which cai? did you make sure to plug the sensor back in? make sure all clamps are tight? i've ran the s&b for a few thousand miles and have not had any check engine lights.
S
SexyAvalancheGrey
Everything was properly put back together including the sensor....... I also have a Tune, Catless DP's, FMIC, Turbo Adapters.......not sure if the tune needs to be altered, I emailed my tuner......
hammer73
Hillsboro, Oregon
If you Dont have them already... O2 extenders on the downpipes....
18 SCrew Magnetic, Roush CAI. Whipple tuned. SPD adapters, Kooks Green catted down pipes. HF & VHF Connected.
Livernois Motorsports
Michigan
Hey guys just so you know it is not the o2 sensor code you gave us for the p04db it is a crankcase vent system issue. Usually that means your current cold air is not flowing as efficient as your stock system. Ecoboost motors do not require a tune for a cold air system but can trigger this code. You either have something loose or you need to look into a different system or try stock system to see if problem persists. My name is Jake message me or call me with any questions or concerns. Thanks 313-561-5500
