ICON Vehicle Dynamics Billet Uniball Upper Control Arm Sytem
Discussion in 'ICON Vehicle Dynamics' started by ICONRep, Oct 17, 2012.
  1. ICONRep
    ICONRep Supporting Vendor Supporting Vendor
    387
    728
    Aug 17, 2011
    Riverside, CA
    [​IMG]
    [​IMG]
    ICON Vehicle Dynamics has developed an on vehicle Adjustable Billet Aluminum Upper Control Arm System for the Ford SVT Raptors. These trucks were designed and built for off-road performance, but have plenty of room for improvement like any factory vehicle. The Weak OEM ball joints present problems by limiting usable suspension travel. The new billet aluminum arms use 1” Teflon Lined all Stainless Uniballs combined with our 17-4 Stainless Taper Pin Adapters to increase the upper arms misalignment, allowing for smooth and clean bump and droop wheel travel without worrying about factory ball joint bind. You can maximize your available wheel travel by adding a set of our 3.0 Ford Raptor Remote reservoir Coil Over Shocks. This Billet Aluminum Uniball Upper Control Arm with our ICON 3.0 Coil Over Shocks will make a huge increase in the performance and handling of your Ford Raptor SVT. Unique to no other Raptor Upper Control Arm on the market to have on vehicle adjustable rod ends to allow for easy alignment adjustment in minutes not hours. That means no taking the arms on and off to adjust them you simply loosen the pinch bolts, adjust to your liking, and re-tighten the the pinch bolts. Our upper control arm system also has a unique o-ring sealed cover cap to keep dirt and weather elements from collecting on top of the uniball, which ultimately leads to tearing up the teflon liner causing you to replace them prematurely.
    Key Features:
    - 6061 Billet Aluminum
    - Precision CNC Machined
    - 1” Teflon Lined All Stainless Uniballs
    - Easily Adjustable on the Vehicle for Perfect Wheel Alignments
    - 17-4 High Grade Stainless Steel Uni-ball Adapter Pin
    - High Precision CNC Machined Pin Provides OEM Like Fitment
    - FK Bearing RSMX Teflon Lined 7/8” Rod Ends
    - O-ring sealed uniball cover cap
    Tech Info:
    Works with or with out aftermarket coil over shocks
    Wheel & Tire Fitment Info:
    Aftermarket Wheels & Tires: Yes
    GBrown1867 likes this.
  2. Reptar
    Reptar FRF Addict
    2,454
    614
    Aug 24, 2010
    Jersey
    wow those are purdy!!!
  3. Blind1
    Blind1 FRF Addict
    59
    12,773
    3,312
    Jan 28, 2012
    Central Alabama
    Real PURDY!!!!
  4. RDFTS
    RDFTS aka Rick Supporting Member
    12,470
    8,625
    Nov 10, 2013
    Southwest Missouri
    I ordered these and should be here next week. It is showing that they work with stock wheels?
    Why is it different on ICON's website?
    Aftermarket Wheels & Tires: Back space 5"
  5. ICONRep
    387
    728
    Aug 17, 2011
    Riverside, CA
    This information was updated due certain factory wheels hitting due to high offset, tire size,and alignment. Bottom line is it was a tight fit to begin with but we chose to take the safe route and mark them as they do not fit with the stock wheels. What you are reading here is from 2012, our website is up to date with correct information.
Share This Page
