*ICON Upper Control Arms* GEN1/GEN2
  • Thread starter Rick@FreedomMotorsports
  • Start date
R
Guest
ICON Vehicle Dynamics have released a new UCA for the GEN2 and will also work on the GEN1. I had a nice phone call with ICON over some recent orders we have done for the new Delta Joint and spoke about a current backorder on their UCA.
They made some changes to work on the GEN2's and they also tested the fit on GEN1's.
If you haven't heard about the new Delta Joint, you need to. Its a heavy duty high angle ball joint with the performance of a traditional uniball. Right now you can get a retrofit ball joint kit to replace in your existing ICON UCA but next year in the 1st/2nd quarter they will be releasing an universal Delta Joint that can replace most UCA that use the traditional uniball. Currently the Delta Joint only works on the stock knuckles.
If anyone is interesting in getting a set of the new UCA or Delta Joints, reply in this thread and I will get hold of you.
Yukon Joe
Russellville, AR
Had anyone received the retrofit kit yet? I'm looking for some feedback on feel and longevity of the Delta joint. I suspect it may be too new (available for 8 months?) for much review information.
I'm looking at the 1" kit to replace the spherical bearing in the RPG raceline UCA.
http://iconvehicledynamics.com/shop...0-non-icon-uca-1-retrofit-deltajoint-kit.html
@Yukon Joe
[emoji830][emoji830][emoji830][emoji830][emoji830]♡♡♡[emoji830][emoji830][emoji830][emoji830][emoji830]
Donate to a fellow raptor owner
http://www.fordraptorforum.com/showthread.php?p=1286274
McGrath4u
@Yukon Joe
Hey Joe,
Reach out to Red (Jeff). He used them and had some opinions about them.
John
R
Guest
Hiw would these been in winter salted roads here in Canada?
I would still try to keep them clean with the salt but of all the UCA's out there, these are protected from the elements more than others. You do grease the delta joint every 3k miles.
