Icon Thrust Offset Help
deucedevil
Phoenix, AZ
Looking for some help on offset/backspacing.
Planning to put on Icon Thrust with the following dimensions when I get my rig in hopefully September. Wondering how much this will change the stance from the regular wheel provide (not headlock or 37). I've researched a little but can't quite understand how it will shift the wheels out if any. Thanks in advance for any help.
Bolt Pattern: 6x135
Offset: 6mm
Backspacing: 5"
Bore: 87.10mm
Also, if anyone is running these on their G2/G3 would love to see pics. Also also, any feedback on these wheels would be great. Have Method 305s on current lifted F150 and love them but want something a little different for new truck. First time Raptor owner. . . .when/if it shows up.
DocMarshall
WV
Factory offset on the 17x8.5 (non 37 pkg) is +34mm, so yours will stick out 28mm more. So 1.1 inches farther out.
blue22raptor
North West, FL
+1 what doc said. A 6mm offset will push your wheels out about an inch. Should look more ”flush”. You will not have any rubbing/scrubbing issues on your truck!
