Raptor911
It’s an interesting idea. Still don’t think it looks better than what Ford offers with the Raptor beadlock set up. I will add the Ford Performance beadlock rings to my Gen 3 as I did to my Gen 2.
You’re completely missing the point of this setup.
No, I am not. Aesthetically it does not look as good as an actual beadlock ring. Moreover, the functionality is questionable. If you have a malfunction with one of the screws on the ICON set up, you will have a flat tire.
How?
Under normal pressure conditions, the wheel works exactly like a regular wheelI believe the screws would only come in to play in “load” conditions. IOW, when you’re running low pressure off road and start doing hooligan stuff.
The screws are there and in play regardless of whether the tire is in a load condition. And that’s my point, if you have any type of failure with the interlock system, so that it allows air to escape, you will have a flat tire. Doesn’t matter whether you are driving on road at normal PSI, or off-road at a much lower PSI. Now maybe the failure rate is such that it is extremely minuscule and not likely. Time will tell.
