I need help!
Slodoc07
Pismo Beach Ca
With all of the products out there I’m extremely overwhelmed and frustrated shopping for what I need. I have ‘19 Metallic Grey Raptor less than 5,000 miles on it. Look for advice on what products I need to maintain the interior and exterior with out over buying. I’m fine with buying quality products, I just want a simple kit that will get the job done. I just purchased a 3200psi pressure washer, drilled out the 0 degree tip so it won’t damage the paint and I plan on purchasing a foam cannon from chemical guys. What else does everyone recommend; soaps, waxes, do I need to clay bar, wheel cleaner, interior products... any advice is graciously appreciated.
also, how would I go about buffing out swill marks from the piano black portion of the door. I don’t know the correct term for that area but it’s where the two doors meet.
Rapt-up
Vero Beach,Florida
I have purchased several different products from chemical guys and they all seem to work well. They have many you tube videos demonstrating every product .
MTF
Celebration, Florida
This guy did an outstanding job.
https://www.fordraptorforum.com/posts/1316402/
I’m pretty happy with Adams buttery wax, detail spray and their new spray on ceramic. The first 2 are very easy to apply and detail spray can be done while wet. I’ve had really good results from this stuff.
hekster1
NJ
Check out The Last Coat. In my opinion it’s a great product. Check out the videos on you-tube. I use it also on the interior and on the outside glass...
Kyle@Apollo-Optics
San Antonio,TX
Ok so to me it sounds like you want to do this right. There is a plethora of places to learn online. I’ve always been into cleaning my vehicles since my first car at the age of 16. It relaxes me. Inside I’ve always felt it as an obsession. Maybe OCD in a way. I’ve been using Adam’s Polishes for 11-12 years now. I’ve learned quite a bit from there video’s. I would say I love 90% of there products. You need to decide what route of maintaining your vehicle you want to go.
Either way it starts with
1. A two bucket wash (buy two buckets with grit guards
2. Two soft wash mitts
3. Drying towels or a master blaster air dryer or a dedicated leaf blower to cut your drying time down.
4. Clay bar. You can’t really pick a bad one because for the longest time one person held the patent for the US and everyone had to use the same. Just different colors and sizes
5. Detail spray. I buy it by the gallon. Use it as the lubricant for coating the vehicle. Go slow. If you go to fast you risk the clay slipping out of your hands and hitting the ground. Once it does that it’s trash. Use small pieces and keep folding it after each panel.
6. Premium towels for wiping down after using the clay bar. I sat at least 12 of them since they will be used for other phases in detailing.
Now I was breaking this down because I don’t know how experienced you are.
Paint correction is the next phase.
You can do this by hand, but it’s going to take forever.
I use a D/A polisher because it’s almost impossible to “burn” the paint like an orbital can.
You can pick you up from quite a few places. Buy a good one so it will last. I believe mine was $350, but I’ve had it for 12 years and haven’t looked at prices of them in quite awhile.
swirls.
On a brand new truck swirl and haze remover won’t be to bad.
They make specific “cutting pads” for removing swirls.
polishing
Same as right above. Use the correct pads for polishing with the polish and remove.
sealing the paint.
You can use paint sealant, machine wax, wax by hand, or the new craze ceramic.
Each one has a different time table.
Normal wax being the least (time depends on quite a few variables 3 months for me) all the way up to over a year+ with ceramic. Wax is the easiest to apply and ceramic scares quite a few people away because if you mess it up most people can’t fix it themselves.
Now your pressure washer. I need more details. Drilling out the orifice hole on your pressure washer tip doesn’t really help you. You have no idea what pressure your at. You said it 3200 psi. Is that true psi? So much goes into this. About 1200 psi is max you’d want to use on paint. Right where it starts to hurt your hand if your holding it in front of the nozzle. When it comes to pressure washing a car it’s not pressure. It’s GPM (gallons per minute). Right at 11-1200 psi and 2gpm is what your looking for.
My go to wand is made by Mosmatic and foam cannon is made by MTM.
now interior.
What seats do you have? Recaro’s or normal leather? Recaro’s are a different animal for taking care of them. More steps and products. Leather, just cleaner and conditioner. I can go on forever.
Adams Polishes site has quite a bit of info and so does Obsessed Garage. Matt @ Obsessed has some awesome video’s and the man has spent 10’s of thousands trying to find the “perfect” products.
If you have more questions just reply or hit my up via PM
I’m a little obsessed with it also
Kyle
Troutrad
Kalispell, MT
I agree, it’s overwhelming.
I think its is Worth putting a Ceramic coating on. Requires a bit of prep to get the paint in shape before you apply but not too bad. After a bunch of research, I settled on the Avalon King product and haven’t been disappointed. Very easy to apply.
First I washed truck carefully with Dawn dish soap. Probably be some debate about that but got it very clean and removed all grease. I used the Griot’s Garage Fine Surface Prep Mitt which is a lot easier than clay. Used their Speed Shine product with the Mitt. Next I used the CarPro Eraser to take the place of dilute alcohol. It is a not a very expensive replacement ( I think it was 15 bucks or so and even after doing the whole truck, looks like I barely used any) and it does include dilute alcohol. Then I applied the Avalon King Ceramic coating.
I’m not a rep or have any interest in any of these products. I had about 2000 miles on my 2019 Ruby Red Raptor so didn’t need to do any other paint prep since I’d babied her for the first 2000 miles.
I’ve only applied one coat of the Ceramic and it only took a few hours. It was so easy, I’m thinking bout laying down another.
Good luck.
One note with the Griot’s mitt. Be a little carefully not to go aggressively over raised paint edges. Go along the length of the edge (parallel to edge). I created some swirls on the edge on my first pass on a raised paint edge on the hood which I had to buff out. After I learned that, it went fine.
AdamsPolishes
On the exterior, there are lots of options, from the very easy products with decent protection to the more advanced products like the ceramics. What is your current level of experience and what is your preferred methodology? Is detailing a hobby of your's, or do you just want to clean the truck and make it look good with less effort?
If you are looking for good protection with less effort, then I would recommend the H2O Guard & Gloss for exterior protection and shine. The great thing about this product is it is applied to and provides protection for all the exterior surfaces; paint, vinyl, glass, rubber and plastic trim, wheels, basically everything except the tires.
Check out his post for a write-up:
https://www.fordraptorforum.com/posts/919004/
On the interior, the Leather Conditioner is great for providing protection to the leather seats, dash and all the textured plastics like the doors. This will leave a bit of shine, so if you prefer a matte finish, use the Leather & Interior Dressing.
For light cleaning, the Interior Detailer is good, for deeper cleaning use the Interior Cleaning Gel.
If you have Recaro seats, check out this How-To post:
https://adamspolishes.com/pages/how-to-clean-suede-interior
These smaller kits would get you started:
https://adamspolishes.com/collectio...ics/products/adam-s-basic-h2o-guard-gloss-kit
https://adamspolishes.com/collectio...ts/products/adam-s-detail-spray-2-towel-combo
https://adamspolishes.com/collectio...its/products/adam-s-leather-interior-care-kit
https://adamspolishes.com/collectio...ing/products/adam-s-carpet-upholstery-cleaner
If you also need washing products, another good kit:
https://adamspolishes.com/collectio...ng-kits/products/adam-s-essentials-detail-kit
Pure745
Orange County
I'm a huge fan of Obsessed Garage - I have strayed from his exact method, but he makes it simple for people (like your question above) shows you what to get and how to use it based on his trial and error.
Watch his Raptor series - drill down into the Raptor playlist, he has about 18 videos of him doing the Raptor. I did a similar process - ceramic coating and drove through some mud over the weekend, it didnt even stick to my paint :)
