Help SupportFord Raptor Forum by donating:
Help support Ford Raptor Forum :
how to reduce intake temps/manifold intake temp without FM IC
Discussion in 'Ford Raptor Engine Discussion and Performance Mods' started by byz250f, May 22, 2019.
  1. byz250f
    byz250f Full Access Member
    341
    136
    Mar 2, 2017
    Im looking to try and drop the manifold intake temps 20F or so on my 19 Raptor. Im not interested in a FM IC that sits in front of the radiator. Im curious if there is an IC, or intake or any other option that can drop the temps.
    Cant run a IC in front of radiator due to the LEDs behind my grill and not wanting to heat up radiator when towing. Stock location only for an IC.
    The 19s now have the ability to see your intake and manifold intake temps on the dash...so very easy to tell if mods make a difference.
  2. nikhsub1
    nikhsub1 Full Access Member
    874
    399
    Mar 5, 2017
    Light bars behind the grill and your asking about lowering temps :facepalm: With that out of the way, there are several companies that make OEM replacement ICs, so if a FMIC is not an option, look to the OEM replacement. The OEM IC is garbage so anything will be an improvement. Unless you block it with your license plate.
    sp2pilot likes this.
  3. MEATSWORD
    MEATSWORD Full Access Member
    128
    40
    Mar 23, 2019
    Arizona
    Or more grill lights!:banana-mario:
  4. byz250f
    341
    136
    Mar 2, 2017
    Baja Design 1 inch wide LED light bar thats at ambient temp is not a 140F heat pump in front of the radiator like all the FM ICs are. From what I have researched an FM IC is about 15-20F cooler manifold intake temps then the stock IC. 15-20F is around a 2% improvement in HP which in stock form is 9hp, not a ton, but also nice to have. If I werent planning on towing I wouldnt worry about doing a FMIC, but I have read of several people in harsh conditions or towing that use a FMIC having cooling issues. I was wondering if anyone has used a meth injection kit, or if its possible to do a killer chiller setup like whats used on the Dodge Demon.
  5. Seartrip
    Seartrip Member
    46
    29
    Nov 21, 2016
    Mishimoto makes a direct fit IC that has a 77% larger core volume than stock and is much better built than the factory IC. I run one because I also didnt want the IC in front of the radiator.
    GotBoost150 and Stroked out like this.
  6. OPT PRIME
    OPT PRIME Full Access Member
    440
    235
    Jun 22, 2017
    Whipple.
  7. WC114
    WC114 Full Access Member
    70
    22
    Jun 25, 2014
    I run the Cobb IC. In S fl. And tow a boat with no issues, the stock fan is pretty strong and should easily pull enough air through to cool the radiator. If your lights are 1" you probably have room for the IC
    Alligator likes this.
  8. Seartrip
    Seartrip Member
    46
    29
    Nov 21, 2016
    Forgot to add- I'm a front license plate state, but I moved my plate to the side to provide as much airflow as possible. Basically did what I could do with the space I had to work with.
  9. MadMaxx
    MadMaxx Full Access Member
    59
    27
    Nov 28, 2018
    Long Island, NY
    Meth Injection.
    wjn, TwizzleStix and wipit like this.
  10. full-race geoff
    full-race geoff Member
    18
    17
    Jun 21, 2012
    AZ / NJ
    GARRETT makes the only stock location Intercooler worth considering IMHO
    Blown00gt likes this.
Share This Page
