- Joined
- Jul 15, 2017
- Posts
- 1,049
- Reaction score
- 952
When it comes to quality, we at SPV are really picky. SPV was started with the foundation of quality. Looking for custom parts for your Raptor or other make or model can be a challenge.
We found that as well when it came to customizing our vehicles. Many vendors offer items that don't fit right, or they look cheap or rust. Many require you to drill or make major modifications.
We decided to take the tough road. To create products that fit. That have proper adjustment. That don't rust... and that look good. That's why we created what we feel is the highest quality and MOST FUNCTIONALLY adjustable one piece bracket out there.
So what needed improved over the other triple mount brackets on the market?
Well, many are stock steel and they rust. Most don't pay close attention to their slots where the fit isn't great. Many have slots one direction or the other.
Ours are-
We are quite proud of our Fog Brackets... but so are everyone that purchases them.
We don't want to just tell you what others say about them. We would rather you hear it from them...
So here is a link to a thread from some very happy customers.
https://www.fordraptorforum.com/threads/man-you-wanna-talk-about-customer-service.78839/
And Another-
https://www.fordraptorforum.com/posts/1521336/
So the next challenge was a quality Custom Fog Harness for the Raptor Fog kits...
The Challenge was.... Different lights have different plugs... What if you mix and match? What if your lights don't have plugs?
Problem solved. Our Newest Fog harnesses have universal plug in bullet connectors and can accept any of our adaptor plugs to connect any connector for any light you have. If you're lights don't have plugs, you can simply connect the other bullet connectors to them to plug and unplug them... Or, add one of our plug kits to your lights and match them up.
But it gets better. Our harnesses also have connectors and opposite end connectors in the kit so you can crimp them on your switch wires. Why? Well, what if you want to add more lights and move your lights on different switches? Or combine them? The permanent crimp on connectors don't allow that. With our kits though... That's a simple task.
If you would like to learn more about our Brackets and Harnesses, you can watch these 2 videos below. They will show you how they compare.
For those of you that may be Offroad Alliance customers.
They also stock our fog brackets.
We in turn stock and offer their bezel brackets. So you can shop at either location comfortably if you are a regular customer of theirs, or of ours.
Both our triple mounts and their bezels are great quality, but are for 2 different applications, so it just depends on what lights you want to install.
Point being, we are all here to help you and we all agree that customer satisfaction and quality products are the most important thing to us all.
New Brackets and How they compare to other designs
Harnesses
Ours are-
- All Stainless Steel
- Our hardware is ALSO stainless steel, not just zinc coated steel (No rust issues)
- Ours have both horizontal AND vertical slots that are strategically positioned. Not only are there crossing slots... that easy, but we contoured them to follow the curvature of the bumper itself. This is important. It isn't straight across.
- Our brackets work with ALL lights. Baja designs, Rigid Industries, and any other pod.
- Our brackets are STRONG. 11mm Stainless steel with black powder-coat. You won't bend them unless you destroy the front of your truck. If you ever have an issue with them, we will gladly replace them.
And Another-
Harnesses
