how the front lighting should looks like
Discussion in 'Ford Raptor Lighting Forum [GEN 2]' started by pla748, Feb 22, 2020.
  1. pla748
    pla748 Member
    47
    4
    Nov 27, 2018
    Usa
    I have a 2018 F150 raptor, which recently was left in the service center for a while. today, I followed my wife's car back home. then she told me my front light looks different.
    my car setting:
    lighting control : auto
    daytime running light setting: on (in information display)
    ambient light condition: sunny day, full bright day light @ 3 PM
    symptom: when driving on the road, only low beam headlight was on, no amber bracket
    does any body confirm me if the amber bracket should be on or not with my setting ?
    thanks
  2. dblack
    dblack Full Access Member
    88
    39
    Sep 15, 2019
    Alabama
    Sounds right if I'm understanding correctly. Unless you've changed it with Forscan your DRL are just essentially the low beams, none of the amber lights.
  3. pla748
    pla748 Member
    47
    4
    Nov 27, 2018
    Usa
    thanks for your reply.
    really confused. please check the video at 4'30".
  4. NASSTY
    NASSTY FRF Addict
    1,559
    1,200
    Aug 19, 2016
    ME
    Although they are talking about the DRL at 4:30 it looks like the headlights are on, not the DRL.
    DRL is low beam only with no other running lights. However that can be changed with Forscan.
  5. pla748
    pla748 Member
    47
    4
    Nov 27, 2018
    Usa
    thanks DBLACK and NASSTY for the confirmation :)
    the Forscan sounds a little fun, will try someday.
  6. pbtjrlmrt
    pbtjrlmrt Full Access Member
    345
    221
    Feb 21, 2019
    Oregon
    2nd
  7. Russ103
    Russ103 Full Access Member
    77
    63
    May 13, 2019
    MD
    I covered my light sensor on the dash with electrical tape so my lights are on all the time. Problem solved.
    I’ve always disliked auto lights. Mainly, it drives me nuts that the sensor has to determine that it’s dark enough to turn your dash (heat, radio, and all lighted buttons) lights on. I want them on all the time personally.
Share This Page
