FRFNewsletter
Well-Known Member
- Joined
- May 4, 2021
- Posts
- 230
- Reaction score
- 0
Click here to view on the web
Highlighted posts
September 12, 2021 * 6 posts * 105 views
Vickc said: 2013 Gen 1 bought this 3 weeks ago, a lot of miles(193k) and going strong. Currently in the process of oem+ restore. Minor things that I'm finding annoying and ugly that I just ... Read more >>
September 13, 2021 * 5 posts * 91 views
Guaso2015 said: I just a purchased a 2018 with the 802A package, torsen Diff in the front, I'm wondering if the Torsen makes the drive slightly rougher. I drove a 2017 model a week before and ... Read more >>
September 12, 2021 * 4 posts * 120 views
Chris Mies said: Slightly off topic, but I highly recommend the Rimrocker Trail between Moab and Montrose. It is 160 miles in total and sections of it are just county roads that you can fly over. ... Read more >>
September 12, 2021 * 3 posts * 96 views
maf1331 said: hello every one I have a 2018 ford raptor it has 120,000 km it is get worse everytime I drive the car first of all it had a rattle sound on cold start so I took it to the service ... Read more >>
September 13, 2021 * 5 posts * 124 views
xtela said: From the service manual. Arrows indicate flow direction. [image] "2014 F-150 Workshop Manual Located inside the transmission case is a thermal bypass valve. The thermal bypass ... Read more >>
September 12, 2021 * 3 posts * 76 views
mattl600 said: Hey all! Have some venom 00 offset wheels coming and eventually want to go with some +2 glass up front for the SVC mid travel setup I'm eventually going to jump into next year. ... Read more >>
September 13, 2021 * 3 posts * 88 views
K223 said: Welcome aboard. Looks like some good times ahead. Your located in the right place to put that truck to work. Enjoy it. Read more >>
September 12, 2021 * 3 posts * 70 views
K223 said: What year is the truck? Could be a roof leak or something else. But evaporator drains on many '19s had leaks from drain into the front passenger floorboard area, close to the firewall. ... Read more >>
September 13, 2021 * 4 posts * 126 views
TAC71 said: Try turning the key on without cranking for 5 seconds ....off for 5 seconds cycle it about 4 or 5 times. Do this before you try to start it when you figure it will have the issue. ... Read more >>
September 13, 2021 * 3 posts * 255 views
RotorOver said: No pictures, but this is from the manual and tells you what you can configure. 1. Engine Oil Pressure 2. Xmsn Fluid Temp 3. Turbo Boost [image] Read more >>
Continue reading...
