High Pressure Gauge and Filler for Bump Stops
TXRaptor
Any recommendations for a good high pressure gauge and filler for the Fox 2.5" bump stops? I have a large air compressor, but no way of checking or filling the bump stops since they are so small.
The shop that installed them had a gauge, but I did not get the name or model.
J DAMAGE
NJ
You need to purchase yourself the same fill chuck they use for charging shocks, no lose 556 schrader chuck with 300psi gauge. RPG makes a nice one.
https://www.rpgoffroad.com/product/air-control-valve-assembly/
or buy the pieces and make it yourself.
TXRaptor
TXRaptor
They should also be filled with nitrogen. Not shop air
I know why they fill tires with nitrogen, but why does it matter with a steel shock?
MatMan
AridZona
Because air is not an ideal gas, so it expands/contracts and also could contain moisture which adds to that effect.
An ideal gas ensures a constant bump stop pressure so you dont get wild pressure swings (some climates see 50-60 degree temp changes during a trip so you can imagine what that does to pressure).
CO2 is a suitable alternative to N2,
RPGs gauge is perfect, highly recommended.
TXRaptor
TXRaptor
Robtor310
Redondo Beach CA
No concerns about the Nitrogen?
My SCREW is set to 110 lbs, according to the shop.
110 is a good starting point. Initially mine were at like 175psi which was too much for my driving/weight.
I havent had any issues. Looking back Id say my ambient temp swings while using were about 20-30 degrees or so max. I checked them a few times to make sure I wasnt bottoming out and the max travel remained fairly consistent.
In a perfect world a nitrogen source on tap would be great. I just dont have that setup nor has there been an issue using regular air to justify it.
TXRaptor
TXRaptor
101,062
60,249
perret113
