KCM
Thanks that’s what I originally thought it could be. Once I fix mine I’ll post here guessing it’s the same.mine turned out to be a vaccum line for the 4wd
Did you ever figure out if it was the vacuum line? My 2013 is making a similar noise.Thanks that’s what I originally thought it could be. Once I fix mine I’ll post here guessing it’s the same.
put your truck in 4wd and see if it goes away. if it does, its a vacuum leak.Did you ever figure out if it was the vacuum line? My 2013 is making a similar noise.
