High idle speed when warm
Discussion in 'Ford Raptor Engine Discussion and Performance Mods' started by djmacc, Jun 26, 2018.
  1. djmacc
    djmacc Member
    19
    3
    Oct 10, 2015
    Recently I have an issue with the idle. I have a 2010 Raptor 5.4 with a E Force S/C with 150,000 miles.It starts fine goes into fast idle as it should then settles in around 650 rpm. After a half hour of driving the idle creeps up and eventually stays around 950 rpm (in park). This is very consistent it always idles fine for the first 1/2 hour or so then ends up at 950. There is a little surge at the 650 idle but very little. I assumed I had a vacuum leak and so I sprayed all the usual places looking for the leak then bought a smoke machine but still no luck in finding a vac leak. I also replaced the Tbody including the IAC and TPS and no change. I tested the brake booster and replaced the break check valve as well. I am running out of ideas which leads me to question the S/C. Outside of a gasket leak at the base of the S/C is there any way it could be the culprit?
  2. 1BAD454SS
    1BAD454SS Full Access Member
    170
    100
    Aug 13, 2017
    bad mass air meter? or leaking hose clamp tubing after meter.
Share This Page
