Tahoetim_42
I'll check it once I get the chance. Thank youThat is odd, can you check the connectors and test for voltage with a multimeter? At least find out if the truck is sending volts to the headlights; from there I would trace the wiring back to BCM (?) and then switch itself. Good luck!
