Here's a good one.
Jughead
SW. Pa Part of the Rust Belt
This happened to me about 2 weeks ago when we were plunged into a polar vortex.
It was about zero out and I went to start the raptor and move it up the driveway so I could blow the drive. I parked it on an incline of my driveway. Not very steep. I had it in 4WD and put it in Park. I took my foot off the brake and the truck starts drifting backward about 8 ft and then stops. WTF?
I repeated this several times thinking it was a fluke incident. Nope happened each time. I tried taking it out of 4wd and setting the parking brake.....no difference. Nothing changed and it happened each time.
Any ideas as to what happened here?
I had an excursion years ago that did something similar only it occassionally jumped out of park when parked on a hill.
Reaper308
Did you try backing it up in the same spot and see if direction of truck made a difference? That way it would have ruled out the surface area? Just a thought.
Ruger
Northern Nevada
It seems to me that the Park pin in the transmission has become damaged. It's either that, or the linkage between the transmission and shift lever has a problem. As this is a safety issue, I think you should use the parking brake from now on until you can get your truck checked out.
Reaper308
Yeah, tried that. Moved up a few feet and back a few feet. Same.
Yeah that definitely sounds like transmission issues! That needs attention ASAP! Good luck keep us posted please.
