Here are some photos and measures for our B&O Subwoofer!
joeyaoyp
Houston
Just bought my 2019 Raptor with 802A, I hate that B&O system.
Trying to find some info about replacing the Sub but cannot find any. So I just took it off the car and tear it down. I hope these photos can help other people that wanna upgrade the Subwoofer.
Also, I will need some suggestions about upgrading the SUB. I do not want to sacrifice the flooring space. Did anyone put the shallow sub on the OEM Box? Does it work out well?
I am given to understand that the ‘18+ b&o is a ported enclosure that doesn’t take well to an upgrade and it’s not easy to wire in anyway. The b&o system rolls off bass starting pretty low in the volume range so just replacing the sub itself won’t buy you much additional bass even so. I have the sony system; or had the sony system, which was much easier to mod in steps, and my first mod was the Kicker 8” shallow sub in the stock box and a 300w kenwood mono amp using speaker level inputs. Much improved.
b&o I believe needs a sound processor like the navtv zen to get you an unfiltered signal.
J
joeyaoyp
Houston
Thank you for the info!!
That is what I saw on some post, said that B&O will need a Zen one to get the unfiltered signal. But I heard someone said they can program on the Forscan, “External Sub” or something, to prevent roll off, is that true? I am just wondering if I set the external sub in forscan, and then I tap a LC2i on the existing sub cable, will that give me a signal for Sub?
most of what I’ve seen here about the Forscan sub settings is subjective, and I believe it was @dhmcfadin who indicated the for scan changes weren’t effectual for bass roll off. Even if it were to do something it wouldn’t eliminate bass roll off, it would maybe make it less.
I’ll happily defer to someone who’s got the b&o system here.
You can save money by doing it right the first time, but unfortunately it’s not a cheap buy in. Best bet is to redo the stereo all at once.
Again, even if you get a shallow mount sub to work; you could probably just re-purpose a ’17 or older sony sub enclosure, you’re limited to about 300w max for that class of sub. That’s enough for about 20-25w rms ... maybe. Factory sony system was 25w ... allegedly.
By the time you’ve done this mod, you’ve spent probably 350 ? in parts. don’t. If you had a ’17 and were on a pretty strict budget I’d possibly think differently, but you’re not going to get there or close with just a sub and amp.
I’d suggest starting out by checking out the under $500 thread in the audio section. Pickup the zen, big @ss battery home runs for the amp(s), sub and box.
if you need the rear area for storage, MTI / Mobile Toyz makes a behind the seat enclosure they sell loaded for about 1k. I have a single 10” JL x 1x500w JL amp. It’s great. If you buy once / cry once, you’ll save in the long run.
I didn’t think I would need to redo the system at first, but one trip on the highway with the windows down and I couldn’t hear the sony system at max volume. At max volume, it didn’t really sound good, then I started noticing that some music was just bad sounding due to the signal... “mixing”(?) the guys at Ford did. I did the upgrade in stages with sub/amp first, then speakers and dynamat, and finally new amps/sub/enclosure and signal processor. I didn’t budget for that big of an upgrade at first, so I spent some extra - like the kicker 8” in the stock enclosure, to at least make some improvement until doing something more significant. Once I had some spare pennies, I followed advice of others here.
I ended up doing
signal processor (DSR1 for me), battery home runs for ground/power
Morel components up front, replaced the tweeter in the pillars with the component piece, wired from the crossover.
left the rear door pioneers in place.
MTI sub / amp
about 75w to the 4 main channels.
adjusted a few times to get sound close to where I want it.
I’m probably about 2500 all in and did the work myself. Total would’ve been about 400 less if I’d done everything at once.
J
joeyaoyp
Houston
I ended up doing
MTI sub / amp
https://mtiacoustics.com/product/ford-f150-13th-gen-and-ford-superduty-4thgen-behind-seat-enclosure/
This product looks really nice. It should be a really nice choice. But I did not see anywhere I can mount my Amp, also I might need to remove my Jack.
I guess I will need to save some money for the whole system upgrade. I saw some people did a PX6 HU, looks really nice.
Hush Car Audio
Aubrey, TX
MTI sell an amp rack that will work with their behind the seat enclosure. Let me know if interested in pricing I'm a dealer for them.
I moved the jack to the undersea storage area.
BDF
I did forscan, added a 10" fox acoustics enclosure, big i know, but with my 300w jl audio digital mono amp and diamond audio dvc 10, it hits really good, just using line level direct from the old sub amp to the new
