That’s pin striping. It happens all the time and that’s a particularly susceptible area to pin striping. The good news is that it looks like it’s not that deep or doesn’t look that deep in the pics.
You should be able to recover with some polishing compound, rubbing compound, a microfiber rag and elbow grease. With black paint, every little scuff shows up.
With a rock chip, you’ll generally clean out the chip area, partially fill with paint, slightly overfill with clear, wet sand down to level with very, very, very, very fine grit sandpaper. You start a little on the coarse side ( I want to say 800 grit, maybe 1000 ) and work your way up to finer - 2000, 2200 grit, then to compound with a rag.
Here, you probably don’t have too much intrusion into the clear so you ‘blend’ it. I’ve recovered a few scuffs that looked like what you are seeing.
I will fully defer to pretty much anyone here, as I am about as far from a body shop professional as you could get. That said, your pictures look like... 3-4 pints of beer.
Good luck !
