Help with blend door actuator
Discussion in 'Ford Raptor Problems and Questions Forum' started by Justimm, Aug 30, 2020.
  1. Justimm
    Justimm Member
    5
    Aug 30, 2020
    Yesterday I replaced the drivers side blend door actuator. Now, when I first turn on truck, drivers side blows very hot air. I can put the temp up to 90, then hit the max cold button, then drivers side starts blowing cold like it’s supposed to. I tried pullling the #15 fuse for a couple of minutes, then putting it back, turned the key to on for a minute or so like “procedure” says to reset it, but still does the same thing.. It’s a 2010 if that matters
  2. Ruger
    Ruger FRF Addict
    8,599
    6,378
    May 16, 2011
    Northern Nevada
    The passenger side blend door actuator on my 2011 is failing, so I am also interested in responses to this thread.
  3. Justimm
    Justimm Member
    5
    Aug 30, 2020
    I actually went in and removed the new one, turned my ignition on, reached under there and made sure door was where I wanted it to be. I put the new one back in, then did the “calibration” and it seems to be good now
    CoronaRaptor likes this.
  4. CoronaRaptor
    CoronaRaptor FRF Addict
    15,367
    4,289
    Dec 17, 2012
    CANADA
    Glad we could help!! ;)
    Justimm likes this.
  5. Ruger
    Ruger FRF Addict
    8,599
    6,378
    May 16, 2011
    Northern Nevada
    I thought that you had to remove the entire dashboard to get to the blend door actuators. No???
    @Justimm would you be willing to post a how-to?
    Justimm likes this.
  6. B E N
    B E N Full Access Member
    547
    302
    May 1, 2019
    Frederick, CO
    There are shortcuts. Google "f150 blend door replacement forum". Depending on which one your doing it can be a pretty quick job.
    Justimm and Ruger like this.
  7. Justimm
    Justimm Member
    5
    Aug 30, 2020
    It’s not pretty, but what I did was pull back the carpet, remove the trim on both sides of center console, loosen screws around ac cage. I then got my handy dandy sawzall and cut the flared end off of the passenger side floor vent. I then took a crow bar and pushed down on the duct so I could pull the actuator straight out the side. No very professional, but I didn’t have to loosen dash to get it out and it took me no time to swap it out. That’s the hardest one to do.. the other 3 are fairly easy to get to
Share This Page
