HELP ENGINE NOISE
FordTechOne
Detroit
Any update, I think I may have the same sound. I describe it as a chatter or valves clicking sound. But I'm no mechanic.
Try putting it in 4WD Auto and see you f the noise goes away. If it does, there is an issue with your IWE system causing the hubs to stay partially engaged
jrc1122
North Carolina
Will do, it currently is in the shop for Cam Sensor codes (Check engine light). I described the sound it made to the service rep when I dropped it off. They may figure it out, they may not.
The Cam phasers were evidently just done by the dealership right before I bought it, so they are going to have open up the timing cover and take a look to see if they borked something up.
That noise I had was only a one time occurrence (thus far). So time will tell. Thanks.
chefsam
I recently had the same rattle noise with my 2018 right around 3,000 rpms then it would go away. This is what they diagnosed, I
picked it up a couple days ago and the noise is gone, so far so good...
I'm at 22,000 miles btw Indiana pretty close to your miles
