- Joined
- Jul 18, 2017
- Posts
- 2,851
- Reaction score
- 1,315
So I'm sure if you own a Gen1 you're either tired of the crappy Halogen bulbs that came with your truck OR your factory HID bulbs are not what they used to be.
Well we have 2 options available from CrystaLux over at 4x4TruckLEDs.com
First, for you halogen-equipped guys who bought Raptors the second they came out... we have our CrystaLux XHP and G11 Series LED Headlight Conversion Kits. These kits don't cause glare and have been selling non-stop for years now (well the G11 for the last year, but the XHP have been around for years beyond that from us).
The difference between the XHP and the G11 is just technology/time. The XHP are still a HOT seller and have always been a great seller but the new G11 series are slightly brighter. The XHP Series have a 6500K temperature and the G11 series have a 6000K temperature. Both are easy to install, although the G11 take up a LITTLE less room.
The G11 series is our recommendation. You can grab them here: http://www.4x4truckleds.com/crystalux-led-headlight-bulbs-for-ford-f-150-2004-2014/
Next up, for the OEM-HID equipped trucks (projector headlights) we have our new CrystaLux 5.0 Series HID bulbs. These bulbs are a direct replacement over the factory HID bulb. Just take the cap off the headlight, remove the old factory HID bulb, pop in the new CrystaLux HID bulb and you are done. These bulbs are rated for 35W ballasts. So nothing else to do. A real simple and easy upgrade. You'll get a bit more light output and a fresh bulb installed. They are available in 3 color temps: 4500K, 5500K & 6000K.
You can grab them here: http://www.4x4truckleds.com/crystalux-5-0-series-hid-bulbs-d3-pair/
Don't forget to use coupon code RAPTORFORUM as well and you'll save 10% at checkout.
