Headlight trim removal
Discussion in 'Ford Raptor Exterior Forum [GEN 2]' started by John Rathjen, Mar 25, 2020.
  1. John Rathjen
    John Rathjen SWATDOC Supporting Member
    159
    58
    Nov 9, 2019
    USA
    Hey guys - is there anything tricky about removing the headlight trim/surround pieces?
    Are they just installed with clips and just pull out, or are there any hidden bolts?
    don't want to break them while removing
    Thanks
  2. smurfslayer
    smurfslayer Be vewwy, vewwy quiet. We’re hunting sasquatch77
    6,563
    4,490
    Removing completely, or popping to pull the grille?
    I’ve not pulled them completely, but have pulled them loose to remove the grille a few times and the inside just pulls loose with clips.
  3. John Rathjen
    159
    58
    Nov 9, 2019
    USA
    Remove completely so I can wrap it
  4. smurfslayer
    6,563
    4,490
    I’ve not done that one, hopefully someone else can assist.
    John Rathjen likes this.
  5. John Rathjen
    159
    58
    Nov 9, 2019
    USA
    ok thanks Smurf
  6. 4rdFan
    4rdFan Full Access Member
    104
    94
    Sep 4, 2019
    Michigan
    Here are the instructions from Ford on removing the trim around the headlight:
  7. John Rathjen
    159
    58
    Nov 9, 2019
    USA
    Awesome thanks bud
  8. 4rdFan
    104
    94
    Sep 4, 2019
    Michigan
    You got it!
  9. MGA
    MGA Member
    18
    3
    Jun 19, 2019
    Haymarket, Virginia
    Any chance someone has the part number for those clips? Lost one on the middle piece that extends into the headlight, thank
  10. goblues38
    goblues38 FRF Addict
    1,380
    1,192
    Oct 27, 2018
    STL
    We use to call them "Jesus Clips" back in my car stereo days. Because you had to "Pray To Jesus" the clips don't break when you pull them off.
Share This Page
